itr wing help
Old Sep 14, 2005 | 01:40 PM
mrdeadman's Avatar
They let me pick
Default itr wing help
when you install an itr wing on a integra that already has the stock wing there are leftover holes right? does anyone have any pics of these holes/what it looks like on? thanks
Old Sep 14, 2005 | 03:54 PM
mrdeadman's Avatar
They let me pick
Default Re: itr wing help (mrdeadman)
does anyone know a site with a picture or something. are these holes visable on the outside?
Old Sep 14, 2005 | 04:53 PM
undagroundrican's Avatar
i dont think that there are any holes left, there should be 2 holes on each side of the hatch for a gsr wing and the type r wing and the fitment should be a perfect swap.
Old Sep 14, 2005 | 05:13 PM
EMJAY's Avatar
yes there are two holes left if you have a gsr. one hole is exposed on each side. you will need to plug it.
Old Sep 14, 2005 | 05:23 PM
Naruto's Avatar
Default Re: (kb12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb12 &raquo;</TD></TR><TR><TD CLASS="quote">yes there are two holes left if you have a gsr. one hole is exposed on each side. you will need to plug it. </TD></TR></TABLE>
actually...on my LS...there was only one "extra" hole on the passenger side. When I read this, I went out and looked at my car Didn't see the other hole.
Old Sep 14, 2005 | 06:02 PM
weak_tec's Avatar
Default Re: (Naruto)
yes there are two holes on the gsr trunk i believe the biggger one on the left side has that white piece of plastic, man taht was a bitch takin it out since it was jammed, no they're not visible once u put on the itr wing
Old Sep 14, 2005 | 07:07 PM
mrdeadman's Avatar
They let me pick
Default Re: (spoon_meeH)
so it doesn't matter if you plug it except that water may or may not get in there?
Old Sep 14, 2005 | 09:01 PM
therealdc2itr's Avatar
i have an oem type r wing on my gsr and i just used some rubber gromets to plug the holes. you can see them. they lay in the inside of the wing. people use different things to plug them and then they paint to match car that way it is not so noticeable. hope this helps.
Old Sep 15, 2005 | 01:52 AM
Naruto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon_meeH &raquo;</TD></TR><TR><TD CLASS="quote">yes there are two holes on the gsr trunk i believe the biggger one on the left side has that white piece of plastic, man taht was a bitch takin it out since it was jammed, no they're not visible once u put on the itr wing</TD></TR></TABLE>
yea I know. I was talking about that extra one where the wiring for the led brake light on the OEM wing went through.
Old Sep 15, 2005 | 06:37 AM
IntegraMastaz's Avatar
There are 2 hole, I had same problem on my Ls. The drive side one should alrady have a white plug in it, The passenger side is wde open.
Like other sed just get a plug that fit the size, paint it and plug it. Unless you got a creazy Billion dollar Show car its very hard to notice.
But make sure you plug it lol or your car will have an interior pool lol.
Old Sep 15, 2005 | 07:54 AM
Stoph's Avatar
there was two holes left exposed on mine. I just found some plugs at the hardware store in the specialty bins with all the screws and stuff.
njmad
Nov 2, 2009 03:16 PM
MichelleAcura98
May 2, 2007 12:12 PM
o0oz
Dec 28, 2006 01:20 PM
SOmbody
Jun 6, 2004 08:48 PM
SMZ GSR
Oct 13, 2002 10:54 PM
