going boost
Old Jan 25, 2006 | 05:33 PM
NosBoost18ls's Avatar
Default going boost
i have a 99 ls think of going boost.i had a 92 ls wit NOS but im bored of NOS.i was told by sum1 2 put a CRV head on my block.n then boost.have any ideas.thank 4 any help.
Old Jan 25, 2006 | 05:43 PM
PrinceAli132's Avatar
Default Re: going boost (NosBoost18ls)
Search, come on i even gave you some good links in your other thread.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FAQ. &raquo;</TD></TR><TR><TD CLASS="quote">
---Engine, LSVTEC and CRVTEC---
https://honda-tech.com/zerothread?id=1119323 – A Few Good Links
https://honda-tech.com/zerothread?id=1082172 – A Few More Good Links
https://honda-tech.com/zerothread?id=1083788 – Break-In Period
https://honda-tech.com/zerothread?id=501372 – Reliability Issues
https://honda-tech.com/zerothread?id=720621 – Quarter Mile Times
https://honda-tech.com/zerothread?id=805408 – Using LS ECU
Taken from this thread - https://honda-tech.com/zerothread?id=1230496
What your refering to is an ls/vtech or crvtec. My opinion is if your going to be boosting then stay with the ls block and head and boost from there. Don't waste money on a vtec head. But its your money and your car and do as you want. This has been covered plenty of times.
Ali
numbnuts22715's Avatar
uhh i dont see any point of putting a crv head on your block...
you could possibly to an lsvtec though.. or just leave it how it is and boost it and get close to/around 300 hp with an excellent tune.
build up a kit, or look into full-race, inline pro, or if you dont mind losing the a/c, check out peakboost kits.
Old Jan 25, 2006 | 05:54 PM
Default Re: (numbnuts22715)
i was thinkin or putin 2gether a kit.buying things off new stuff off ebay.
Old Jan 25, 2006 | 05:56 PM
Default Re: (NosBoost18ls)
Personally, i would stay away from most things from ebay. We have a great sponosor section on here will good deals on just about everything you could want or need.
Ali
Old Jan 25, 2006 | 06:06 PM
1turbodc2's Avatar
agred with ali
also what are your power goals, daily driver, smog an issue? and how much are u looking to spend these will help in giving u advice but bottom line u need to do a lot of research it is not a bolt on affair by any means and u can have the best turbo systemm but without good fueling and good engine mangement , and a good tune it is worthless
EKjdmCTR
Apr 3, 2007 02:48 PM
91turboteg
Sep 18, 2006 03:21 PM
xstalkrx
Jun 29, 2004 12:22 PM
pcorad
Dec 29, 2003 02:54 PM
