engine bogs
Old Jan 24, 2006 | 07:50 PM
i_see_red's Avatar
Default engine bogs
okay, here's the deal. newbie to tuning so therefore lack of knowledge. have helm's manual at hand but still need help trouble shooting. anyway, i just replaced everything listed below:
fast idle valve o-rings, throttle body gasket, intake manifold gasket, pcv valve, fuel pressure regulator o-ring, all the fuel injector rings, EACV o-rings, ran coolant line straight to EACV bypassing the throttle body, removed the hose from intake pipe to valve cover and replaced it with a k&n breather filter, valve cover gasket, adjusted valves.
now, here's the problem. everything looks fine. car starts with no check engine light. idles fine too. but when i try to drive it, it bogs BAD. but it starts picking up at about 5000-6000 RPM. since i did all that crap i listed above, i don't know where i went wrong. suggestions?
i'd also removed the timing belt to adjust the cam sprockets cause they weren't lined up at TDC. i'm sure i did this right cause every valve i adjusted, the lobe was pointing the right direction and it matched the TDC on both sprockets and crankshaft. but i don't know, i might have screwed up somewhere.
anyway, any help will be greatly appreciated.
thanks
Old Jan 24, 2006 | 07:51 PM
i_see_red's Avatar
Default Re: engine bogs (i_see_red)
opps...engine is a 92 LS
Old Jan 24, 2006 | 08:14 PM
wytechoppin's Avatar
have you checked you ignition system? check you coil and also when you take out the cap se if its crack of any sort..
Old Jan 24, 2006 | 08:18 PM
i_see_red's Avatar
Default Re: engine bogs (wytechoppin)
hmm...i didn't mess with that but i'll check it tomorrow. any other suggestions?
Old Jan 25, 2006 | 09:01 AM
i_see_red's Avatar
anyone? anyone? i need help badly!
MC Slide Hammer
Apr 21, 2011 04:42 AM
Mr_ET
Jun 29, 2007 04:01 PM
96v6terror
Nov 6, 2006 07:11 AM
hondadriver
Mar 14, 2006 08:03 AM
Qwikrex
Nov 19, 2002 05:02 PM
