brake bleeding
Old Jan 24, 2006 | 05:17 PM
alex_s817's Avatar
Default brake bleeding
i just changed the front brake rotors and pads on my 94 ls. i had both calipers off at the same time and when i was finishing the left wheel, i forgot the right caliper was still off. i had a friend pump the brake pedal to make sure i finished the left side correctly and the piston on the right caliper came out way too far. if i bleed the line, will it compress?
Old Jan 24, 2006 | 05:26 PM
GoCarInteg's Avatar
Default Re: brake bleeding (alex_s817)
you can't just push the piston back in?
Old Jan 24, 2006 | 05:30 PM
alex_s817's Avatar
Default Re: brake bleeding (GoCarInteg)
i tried that, i got a 6 inch clamp and put it up to an old pad on the top of the piston and clamped it down as far as i can and it wont even budge. i hope nothing is broken ???
Old Jan 24, 2006 | 05:39 PM
alex_s817's Avatar
so will the bleeding make it compress??
Old Jan 24, 2006 | 05:56 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alex_s817 &raquo;</TD></TR><TR><TD CLASS="quote">if i bleed the line, will it compress?</TD></TR></TABLE>
No.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alex_s817 &raquo;</TD></TR><TR><TD CLASS="quote">i tried that, i got a 6 inch clamp and put it up to an old pad on the top of the piston and clamped it down as far as i can and it wont even budge. i hope nothing is broken ???</TD></TR></TABLE>
The clamp is a bad idea, as it oftem jams the piston. Hopefully you did not damage it. I suggest this:
1) Remove the pads from the caliper
2) Open the bleeder on the caliper.
3) Pull the piston boot away from the caliper to make sure that it will not interfere with the piston.
4) Twist (back and forth) and gently push on the piston to reinsert it into the caliper body. It should slide back in.
5) Retighten the bleeder.
6) Bleed your brake system.
You can find a full Helm manual online. Search Google for "hondahookup manuals".
Old Jan 24, 2006 | 07:22 PM
alex_s817's Avatar
Default Re: brake bleeding (Dogginator)
thnkas for the help, but its too late. when i went to bleed the line, as soon as i cracked the valve, fluid came out of the piston boot! did i just screw myself or can i fix it somehow? thanks
Old Jan 24, 2006 | 07:44 PM
alex_s817's Avatar
please help, i need it driveable tomorrow..
Old Jan 24, 2006 | 08:11 PM
pat.ter.rick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alex_s817 &raquo;</TD></TR><TR><TD CLASS="quote">thnkas for the help, but its too late. when i went to bleed the line, as soon as i cracked the valve, fluid came out of the piston boot! did i just screw myself or can i fix it somehow? thanks</TD></TR></TABLE>
your screwed..you gotta change it now..
Old Jan 24, 2006 | 08:29 PM
alex_s817's Avatar
Default Re: brake bleeding (g0t vtec-)
damnit anyone know where and how much a new one is? **** this sucks
Old Jan 25, 2006 | 04:11 AM
Dogginator's Avatar
Daisy... Daisy...
Of course fluid would exit the boot; you popped the piston. You can still reinstall it with the steps I listed above. Have you looked up a manual?
A rebuilt caliper is about $60 if I recall correctly.
Old Jan 25, 2006 | 05:25 AM
alex_s817's Avatar
i will try it but i think my main problem is i was trying to bleed it while it was off of the rotor. the whole reason i was bleeding it was to get it to fit back on without hurting it......
Old Jan 25, 2006 | 08:59 AM
IVI's Avatar
IVI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
No.
You can find a full Helm manual online. Search Google for "hondahookup manuals".</TD></TR></TABLE>
i agree.
Old Jan 25, 2006 | 02:51 PM
alex_s817's Avatar
Default Re: brake bleeding (IVI)
thanks for all of the help, i took the advice and give it a few turns with pliers and it went right back in. how long will it take to get the feel of full braking?
Old Jan 25, 2006 | 02:59 PM
Dogginator's Avatar
Daisy... Daisy...
I'm glad that it worked. You may have a lot of air in the line. Keep bleeding until it is all out. Brake fluid is cheap.
Old Jan 26, 2006 | 03:55 PM
alex_s817's Avatar
my brake pedal is very soft, and they dont work at all. do i just need to bleed the one line that i had trouble with, or all four of them in order for it to work correctly?
Old Jan 26, 2006 | 03:58 PM
Dogginator's Avatar
Daisy... Daisy...
Since the line was open for an extended period, you probably have air to the master cylinder. You need to bleed all four lines and the ABS. Did you search google for "hondahookup manual"?
Old Jan 26, 2006 | 04:01 PM
alex_s817's Avatar
ill try it, do you know of a link or somewhere i can find a diy on how to do it? thanks for all the help
Old Jan 26, 2006 | 04:08 PM
Dogginator's Avatar
Daisy... Daisy...
I do not know of a link, though I'm sure that one exists. The Helm manual is all that you need.
Old Jan 26, 2006 | 04:17 PM
alex_s817's Avatar
thanks
zhan28
Apr 24, 2008 06:29 PM
Fatcobra
Mar 27, 2007 11:45 AM
jEE
10
Apr 11, 2006 05:56 PM
IntegraAlteeza
Jul 23, 2005 11:07 AM
misterxhybrid
Nov 7, 2003 08:31 AM
