TROUBLE STARTING
Old Jan 26, 2006 | 04:25 PM
I got a honda's Avatar
Default TROUBLE STARTING
so my car used to make that clicky noise when i would try and start it and it would not start....so i replaced the starter...well now its doing it again...car wont start..hesitates...also lights are all dim while trying to start..and eventually if i keep the key turned then the car will fire right up....but it doesnt do that clicky noise anymore...does that mean its my battery now??....
Old Jan 26, 2006 | 04:33 PM
DirtyBirdJR's Avatar
Default Re: TROUBLE STARTING (iluvboost)
check your battery and alternator
Old Jan 26, 2006 | 04:40 PM
Default Re: TROUBLE STARTING (DirtyBirdJR)
so even the alternator would cause for this slugish start up?? thanx
Old Jan 26, 2006 | 04:44 PM
first off you need to test battery, if it is bad replace. once you have a good battery test alternator
Old Jan 26, 2006 | 05:03 PM
rkrone's Avatar
also check you grounds
Old Jan 26, 2006 | 05:06 PM
Default Re: TROUBLE STARTING (rkrone)
i was also going to say your connections, and wires from the battery make sure they are not all corroded
Old Jan 26, 2006 | 05:08 PM
hhmm yea ill get off my *** and do that thanx again
Si_eg6
Jul 14, 2008 02:47 PM
RyCeRoCkeTz
10
Apr 17, 2007 12:19 PM
tigueremalo
Jan 22, 2007 03:10 PM
B18 CYA
Oct 29, 2004 07:59 PM
Spalude
Sep 30, 2004 08:47 AM
