engine light
Old Jan 25, 2006 | 02:38 PM
vietnogi's Avatar
Default engine light
Any one knows that would cause the engine to shake violently while idleing?
When i start the car, the engine lights turn on.... and after a min, the motor begins shaking and the engine light begins to blink. Recent service on the car includes a transmission fluid change from honda dealer. They also washed my car and cleaned the engine bay. I had a cold air intake on and was sure the filter was soaked.
Old Jan 25, 2006 | 03:12 PM
vietnogi's Avatar
Default Re: engine light (vietnogi)
any one got any ideas?
Old Jan 25, 2006 | 03:16 PM
Dogginator's Avatar
Daisy... Daisy...
Pull the CEL codes. It will most likely tell you what the problem is. What car/engine/ECU/OBD?
Old Jan 25, 2006 | 04:56 PM
vietnogi's Avatar
Default Re: engine light (Dogginator)
sorry im a noob, how would i get the cel code? go to a shop? or buy something from pep boys? god i hope i have enough month to eat within the next month.
Old Jan 25, 2006 | 04:59 PM
Racermech's Avatar
https://honda-tech.com/zerothread?id=978933
That tells you how to check the CEL and then tells you what the code means
Old Jan 25, 2006 | 05:01 PM
Dogginator's Avatar
Daisy... Daisy...
There is information here on how to check the CELs.
http://www.honda-acura.net/for...12463
Old Jan 25, 2006 | 05:03 PM
vietnogi's Avatar
Default Re: engine light (Racermech)
thnx, i'll do it first thing toomarrow and get back to u guys.
Old Jan 25, 2006 | 05:53 PM
Dogginator's Avatar
Daisy... Daisy...
In all honesty, that should take less than five minutes.
Old Jan 26, 2006 | 09:46 AM
vietnogi's Avatar
okie, i beleive its 7 long and 1 short, so the error code is 71 random misfire in cylinder 1... what would cause this problem? and could i still drive to a shop? or how can i fix it. thank for your guy's time. Oh yea, its a 97 gsr, eveyrthing should be stock, beside cia
Modified by vietnogi at 11:02 AM 1/26/2006
Old Jan 26, 2006 | 09:49 AM
vietnogi's Avatar
could the dealer caused this?
Old Jan 26, 2006 | 09:58 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietnogi &raquo;</TD></TR><TR><TD CLASS="quote">okie, i beleive its 7 long and 1 short, so the error code is 71 random misfire in cylinder 1... what would cause this problem? and could i still drive to a shop? or how can i fix it. thank for your guy's time. Oh yea, its a 97 gsr, eveyrthing should be stock, beside cia</TD></TR></TABLE>
Bent valves in cylinder 1, poorly adjusted valves in cylinder 1, or a faulty injector in cylinder 1
Do a compression check.
Old Jan 26, 2006 | 10:05 AM
vietnogi's Avatar
could i still drive around? could this of been caused by my intake suking in water?
Old Jan 26, 2006 | 11:41 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietnogi &raquo;</TD></TR><TR><TD CLASS="quote">could i still drive around? could this of been caused by my intake suking in water?</TD></TR></TABLE>
Yes. You could have bent a connecting rod in that case.
Old Jan 26, 2006 | 02:56 PM
vietnogi's Avatar
phew problem solved, just droved it to local mechanic and got a diagnose... stupid dealer got water into my spark plugs and etc. got compresion test to, was
180
180
180
180
so i assume thats normal. thanks for everyone's input
Old Jan 26, 2006 | 03:11 PM
Dogginator's Avatar
Daisy... Daisy...
Did they somehow ruin the spark plugs? What was done to fix the problem? The compression numbers look good.
Old Jan 26, 2006 | 03:25 PM
integra3586's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietnogi &raquo;</TD></TR><TR><TD CLASS="quote">Any one knows that would cause the engine to shake violently while idleing?
When i start the car, the engine lights turn on.... and after a min, the motor begins shaking and the engine light begins to blink. Recent service on the car includes a transmission fluid change from honda dealer. They also washed my car and cleaned the engine bay. I had a cold air intake on and was sure the filter was soaked.</TD></TR></TABLE>
while the MIL is flashing it means the engine is misfiring at that instant. when it stops flashing it just stored the misfire code in the ecu
cennouu
Jan 12, 2011 07:49 PM
hkhaperey
Apr 30, 2007 07:15 AM
vietnogi
Jan 24, 2006 04:24 PM
CaliRockrr
Nov 26, 2005 04:37 PM
roller
Jun 13, 2004 11:57 PM
