DA wiring help needed...
Old May 6, 2006 | 01:34 PM
BoostinEJ1's Avatar
Default DA wiring help needed...
I was just wondering what some things were on my pass. harness and engine harness so I took a few pictures hoping someone can help me or maybe if there is a site with pictures that have everything labeled? I dunno but I got rid of AC,CC, PS, and ABS so if any of these things have to do with that I would like to get rid of them. Also If anyone knows what you do about a MAP sensor when you swap in a motor because I know the DA has it on the firewall stock but my ITR motor is on the TB and there is no plug for it on the engine harness. Sadly my friend cut everything up by the driver side firewall so maybe if there was once a plug up there for the MAP I can tap into where he cut and extend to the TB? Thanks for any help.
This is off the engine harness, I think it plugs into the pass. harness but for what I dunno... There is also a green plug thats right near this one that I'm not sure about...
These are at the end of the pass. side harness and I think its for the options I got rid of so if so can i cut them? Do i need the black boxes as well?
Old May 6, 2006 | 01:58 PM
NJcoupe's Avatar
resize them.
Old May 6, 2006 | 03:00 PM
JDMDA93's Avatar
Default Re: DA wiring help needed... (simple DB2)
Does wires are for the motor fans. an yes i believe you need em onless you want you're fans not work 2.
Old May 6, 2006 | 09:35 PM
BoostinEJ1's Avatar
up
Old May 7, 2006 | 05:20 AM
BoostinEJ1's Avatar
ttt
Old May 7, 2006 | 06:17 AM
G2TegGuy's Avatar
Default Re: (simple DB2)
As far asthe map sensor issue, youhave 2 options: Continue to use the stock DA Map sensor or extend the wiring and use the ITR's on the TB. Personally I would use the ITR's. Looks cleaner IMO. Then you can trash the existing map along with the Evap purge sole and Fuel Press Reg. Sensor which are all on that one bracket. It cleans up the engine bay a little. HTH
Old May 8, 2006 | 06:58 PM
BoostinEJ1's Avatar
anyone else about the plugs pictured?
Old May 9, 2006 | 06:21 AM
G2TegGuy's Avatar
The pic is kind of blurry but that green plug could possibly be for your vtec oil pressure sensor. Have you wire vtec up yet? I know mine has (1) blue (1) black.
Nate Boslet
Apr 17, 2017 05:16 AM
rsw912
Jul 11, 2012 03:06 PM
asigler
Jul 22, 2009 10:59 AM
turboblack2door
Jun 8, 2008 09:24 AM
gotboosthatch
Feb 1, 2008 09:10 AM
