installing headers
Old May 5, 2006 | 06:59 AM
hwtfan's Avatar
Default installing headers
i am about to order headers for my 96gsr and i was just wonder how difficult this will be for me to install myself i also am getting a highflow cat and new exhuast so yeah how difficult is this about to be??
Old May 5, 2006 | 07:01 AM
db8gsr_teg's Avatar
so easy that it took me 30-40 min. all you need is a 10mm, 12mm, and a 14mm
Old May 5, 2006 | 07:07 AM
integracura's Avatar
only hard part is getting under the car.
Old May 5, 2006 | 07:23 AM
Sijray21's Avatar
you only have one header - it's not plural
if it's a 2-pc header then it will be much easier to install. Just jack it up and install.
with a 1-pc you'll need to jack it up fairly high or use a lift.
Problems include - potential for rusted bolts. That's pretty much it. The install is pretty basic, just make sure you install the gaskets with the pipe.
Old May 5, 2006 | 07:28 AM
purplegsr's Avatar
Default Re: (Sijray21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sijray21 &raquo;</TD></TR><TR><TD CLASS="quote">if it's a 2-pc header then it will be much easier to install. Just jack it up and install.
Problems include - potential for rusted bolts. That's pretty much it. The install is pretty basic, just make sure you install the gaskets with the pipe.</TD></TR></TABLE>
I agree completely, it's fairly easy, but you have to remember to put the gaskets back on (remember to re-use the donut gasket that is between the cat and the b-pipe). Here's a How-To:
http://www.c-speedracing.com/h...r.php
Old May 5, 2006 | 08:10 AM
}-Black-Ls-Stunna-{'s Avatar
Default Re: installing headers (hwtfan)
its fairly easy to install...me and my buddy just installed a header, high-flow cat and catback exhaust on my teg last weekend...it only took about a 1hr 30mins..but like stated above you will most likely run into rusted bolts...and make sure u use gaskets....good diy project u can learn alot of things....also if u like me not alot of money u can diy instead of paying a exhaust shop a arm and a leg to install.
Powered by VTEC
Jan 26, 2008 09:03 PM
boost93
Sep 23, 2005 05:54 AM
Ryuji
Oct 22, 2002 08:52 AM
CzanSOHC
Audio / Security / Video
Sep 6, 2002 07:46 PM
