2 check engine lights
Old May 5, 2006 | 05:48 AM
95_red_dc's Avatar
Default 2 check engine lights
my crx has a b18b swap in it and i have been trying to get it running right for a while it is throwing to codes it is converted to a obd1 there it a code 4 for camshaft posotion sensor and code 7 for throttle body sensor know for the throttle body sensor was brocken when the motor was shipped so i put the old won off my old motor on it but it is htrowing a code is there any adjustment needed, and what kind of condition would my motor be running like if those two are bad , because it idles rough and it surges alittle bit please help me im tired of messing with
Old May 5, 2006 | 06:13 AM
DC2 Mang's Avatar
Default Re: 2 check engine lights (91cleancrxsi)
sounds like you may have a short in the wire for the TPS sensor
for the crank position sensor that is in youre distributor and the only real way to fix that is to buy a new dizzy
Old May 5, 2006 | 04:34 PM
95_red_dc's Avatar
Default Re: 2 check engine lights (JDMdc2lsVtec)
bump
Old May 5, 2006 | 04:46 PM
Yambor's Avatar
the tps sensor should be calibrated , closed throttle voltage set too when swapping sensors..
Old May 5, 2006 | 06:06 PM
95_red_dc's Avatar
Default Re: (Yambor)
how do you calibrated, and set the closed throttle voltage but that would throw a check engine light and would it make it idle bad
95_red_dc
May 5, 2006 06:23 PM
hondaeg8
May 14, 2004 10:23 AM
igone916
Mar 3, 2003 08:59 PM
98teg
Jun 4, 2002 04:25 PM
D1ANCER
Mar 27, 2002 06:06 PM
