can you help electrical problem?????????????
Old May 4, 2006 | 06:05 PM
fthesys's Avatar
Default CAN YOU GUYS HELP ME WITH MY DA'S LIGHTS ?????????????
ok i have a 93 da my turn signal went out i think you call it the cuatro lights not sure. does anybody know whats wronge i checked the fuse and tryed every thing please help if you can. there is no power in the wire at all.
Modified by fthesys at 7:17 PM 5/4/2006
Old May 4, 2006 | 06:20 PM
fthesys's Avatar
Default Re: CAN YOU GUYS HELP ME WITH MY DA'S LIGHTS ????????????? (fthesys)
Old May 4, 2006 | 06:32 PM
fthesys's Avatar
someones got to know something
Old May 4, 2006 | 08:07 PM
dc5_integra's Avatar
Alright... There are a couple things that could cause that. First being that the relay could be bad causing no voltage to occur. Is there no voltage when the turn signal is on or is there no voltage when the turn signal is off? Because with it off there shouldn't be because the relay isn't completing the circuit. To find out for sure if the relay is good or not just jump the hot wire before the relay to the wire after it and see if it lights up. The turn signals need to be turned on though. If they turn
turn on you will then know then the relay is the problem and all the wires are all connected. If thats not the problem then it could be a flasher, loose ground, or the power wire could be cut somewhere. I would go over all the wiring and everything.
I hope this helps a little.
Phrog
Jan 31, 2014 01:12 PM
jdreadjdm
Jul 1, 2012 04:35 PM
efcivic2dr
Mar 29, 2008 01:57 PM
polaris80
Apr 20, 2007 04:13 AM
johnnyb1231
Jan 25, 2006 11:57 AM
