cant get into reverse
Old May 4, 2006 | 11:12 PM
atmosphere's Avatar
Default cant get into reverse
did an engine swap.... excited about the swap so ive been driving hella hard...
wake up one morning and i cant get into reverse. ive been pushing my car out of the garage each morning.
1,2,3,4 all work fine....5 is hard to get into but still works. cannot get into 6th at all.
its a 99 usdm gsr tranny.
what is causing this? what can i do? rebuild whole tranny or buy an lsd? for anyone who helps me, thank you.
Old May 4, 2006 | 11:25 PM
dohcMONSTER's Avatar
Default Re: cant get into reverse (atmosphere)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atmosphere &raquo;</TD></TR><TR><TD CLASS="quote">
its a 99 usdm gsr tranny. </TD></TR></TABLE>
you dont have a 6th gear.
what is causing this? what can i do? rebuild whole tranny or buy an lsd? for anyone who helps me, thank you. </TD></TR></TABLE>
try flushing all your tranny fluid out and replacing it with synchromesh. Sounds like your tranny might seize soon. Have you tried going from neutral to Reverse, its hard on all hondas to get it into reverse sometimes
Old May 5, 2006 | 04:44 AM
numbnuts22715's Avatar
or stick it into 2nd or 4th then go over to reverse.
Old May 5, 2006 | 02:07 PM
atmosphere's Avatar
Default Re: cant get into reverse (dohcMONSTER)
oh **** my bad i made this post late at night...i no theris no 6th.....ill try that ****...i went to a shop they said its prob my shift fork. charging around 750 for labor plus parts...jesus...thats way to much man.
Old May 5, 2006 | 02:09 PM
atmosphere's Avatar
also...i jus did the engine swap and put all new honda fluids in... would this be neccessary to try out the synchromesh...
if so wat brand?
Old May 5, 2006 | 02:13 PM
Dogginator's Avatar
Daisy... Daisy...
Honda MTF is fine. It certainly could be a shift fork. Have you tried shifting to neutral, releasing the clutch, depressing the clutch, and then trying for reverse?
Old May 5, 2006 | 03:22 PM
B18c5__Owns's Avatar
From: I Bet You Really Want To Know Where In, NJ, USA
Default Re: cant get into reverse (Dogginator)
Did you grind any gears by pushing it. Cuz if you did u probably screwed up ur synchros. Did the same ****
Old May 5, 2006 | 04:36 PM
96 GSR-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Honda MTF is fine. It certainly could be a shift fork. Have you tried shifting to neutral, releasing the clutch, depressing the clutch, and then trying for reverse?</TD></TR></TABLE>
I was told by a reputable person that the tranny fluid in the manuals is just motor oil, I was skeptical so I switched to syncromesh
Old May 5, 2006 | 05:16 PM
PirateTypeArgh's Avatar
Default Re: cant get into reverse (96 GSR-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">I was told by a reputable person that the tranny fluid in the manuals is just motor oil, I was skeptical so I switched to syncromesh</TD></TR></TABLE>
yeah.. go put some random motor oil in there and see how long it lasts..
Old May 5, 2006 | 05:17 PM
Dogginator's Avatar
Daisy... Daisy...
The Helm manual says that you can use 10W30 temporarily. Honda MTF is essentially the same base as motor oil, but the additives differ.
Old May 5, 2006 | 05:53 PM
96 GSR-T's Avatar
The Helm manual says that you can use 10W30 temporarily. Honda MTF is essentially the same base as motor oil, but the additives differ.</TD></TR></TABLE>
So he was right in some sense, I didnt use it but he was somewhat correct
Old May 5, 2006 | 11:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">So he was right in some sense, I didnt use it but he was somewhat correct</TD></TR></TABLE>
i actually swapped out my tranny oil today, to redline.. and i gotta tell you.. that stuff is NICE.. i went to the drag tonight and (didnt do that great) but i could definently feel the difference.. for redline
tenedor sports
Apr 13, 2007 07:06 PM
ek_James
Sep 26, 2006 05:23 PM
ej1point8
Mid-Atlantic (Sales)
11
Sep 4, 2006 10:10 PM
Yellb16crxsi
21
Dec 13, 2003 08:48 PM
