b18b fuel problems
Old May 3, 2006 | 12:51 PM
Pnoyej6's Avatar
* B A N N E D *
Default b18b fuel problems
My bro is having problem with his car. He has b18b with 18 g greddy turbo kit. dsm 440 injectors/ obd 1 ecu tuned with crome pro. He is trying to smog his car so he put the ls ecu back on with blue box and 310 cc. It leaks gas on injectors. So he went ahead and say screw it and put the old setup back in he wired up the dsm 440 resistor box in the fuel rail and put the old tuned crome pro obd 1 ecu back on and now his fuel fump does make the whirrl noise when he puts the ignition on. It seems like no fuel is priming the injectors. we dont hear the pump anymore. ?Also we notice white smoke coming out of exhaust alot of it. What could be the problem. He notice the seals on dsm injectors were worn out so he replaced them and now when he starts no fuel pump noise when ignition on. It was working before but blowing lots of white smoke. Everything is connected btw.
Old May 3, 2006 | 12:55 PM
rgaray's Avatar
Pop the rear seats and hard wire the pump. If that works, then go to the main relay and test that.
Old May 3, 2006 | 12:57 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: (rgaray)
how do i test that ??
Old May 3, 2006 | 02:38 PM
rgaray's Avatar
What year is it?
First, test the harness that plugs to the fuel pump. If there's no power there, unplug the harness connected to your main relay, jump the wire coming from the ecu to the wire going to the fuel pump.
You'll need to know which wire is which. I think OBD1 is different from OBD2.
Modified by rgaray at 4:04 PM 5/3/2006
Old May 3, 2006 | 02:59 PM
Pnoyej6's Avatar
* B A N N E D *
obd 2. do i use multimeter to test it
Old May 3, 2006 | 03:05 PM
rgaray's Avatar
Yes, you can.
B18C4-T
Aug 1, 2013 07:11 AM
rlembitz
Dec 24, 2010 09:04 AM
dayl
21
Apr 13, 2010 08:06 PM
CLE
Jul 13, 2006 02:25 PM
Sinner
Jun 6, 2003 02:25 PM
