Boostin the ls
Old Sep 15, 2006 | 07:09 PM
91turboteg's Avatar
Default Boostin the ls
Hey everybody.
I'm just wondering how much boost/ hp the stock b18a block can handle
any information will be helpful
ps; tried searching
thanks
Old Sep 15, 2006 | 07:13 PM
.brian.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91turboteg &raquo;</TD></TR><TR><TD CLASS="quote">
ps; tried searching
you are the failzor at searching
https://honda-tech.com/zerothread?id=1641037
https://honda-tech.com/zerothread?id=1517870
https://honda-tech.com/zerothread?id=819653
https://honda-tech.com/zerothread?id=269853
Old Sep 15, 2006 | 09:20 PM
geerexx's Avatar
Default Re: (.brian.)
it's all about the tune...
Old Sep 16, 2006 | 06:45 AM
SilentHill's Avatar
Default Re: (geerexx)
check this thread out
https://honda-tech.com/zerothread?id=1323059 263 pages of replies you must have not searched for this
Old Sep 16, 2006 | 07:01 AM
DARKTEG_'s Avatar
Default Re: Boostin the ls (91turboteg)
14.5 psi
Old Sep 16, 2006 | 11:41 AM
GoldCoin's Avatar
my friend used to go 12lb daily driven before he got a k20swap done on his ekhatch .
Old Sep 16, 2006 | 11:57 AM
god.loves.ugly
Guest
Posts: n/a
stock internals?
I wouldn't go more than 8-10 keep it on the safe side if its your daily driver.
Old Sep 16, 2006 | 11:58 AM
GoldCoin's Avatar
Default Re: Boostin the ls (god.loves.ugly)
sorry i dint read the guy had stock internals. my friend has fully built. sry shouldve read clearer
Old Sep 16, 2006 | 02:36 PM
91turboteg's Avatar
Sorry should have made it more clear how much HP can the block handle
i'm seein alot around 250 can i go higher
Old Sep 16, 2006 | 02:42 PM
god.loves.ugly
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91turboteg &raquo;</TD></TR><TR><TD CLASS="quote">Sorry should have made it more clear how much HP can the block handle
i'm seein alot around 250 can i go higher</TD></TR></TABLE>
do you have stock internals? if so then 250 would probably be about what you can get out of it. with a good tune. as soon as you start building the motor you can make more power.
Old Sep 16, 2006 | 04:40 PM
sherw00d's Avatar
my boy sean is running 16lbs on a stock ls motor
Old Sep 16, 2006 | 05:03 PM
91turboteg's Avatar
Yes I have stock internals.
btw. why don't people understand that
lbs of boost doesn't mean **** unless you describe what size turbo you have
Old Sep 16, 2006 | 05:14 PM
Ruben19's Avatar
Default Re: Boostin the ls (sherw00d)
it wont last very long.
you must upgrade your internals if you are running 16lbs boost.
watch it blow soon
Old Sep 17, 2006 | 12:08 AM
SilentHill's Avatar
Default Re: Boostin the ls (Ruben19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 &raquo;</TD></TR><TR><TD CLASS="quote">it wont last very long.
watch it blow soon</TD></TR></TABLE>
agreed, 16 sounds rather high, most people with boosted applications i have seen running stock internals run 8 psi safe and not really ne thing more than 12. 16lbs of boost on a cold day when the air density is higher just watch......
Old Sep 17, 2006 | 10:13 AM
91turboteg's Avatar
Default Re: Boostin the ls (SilentHill)
he could run 16lbs all day long on a dsm t25, but not on anything bigger
it's all about how many cfm's your turbo can or will push
Old Sep 17, 2006 | 11:08 AM
adseguy's Avatar
Oh really?
16-17lbs on a 57trim .63turbine t3/t04e DAILY DRIVEN FOR 2 YEARS!
I tuned it and it runs great. I now have a built engine, but it had great compression till the end. 300whp seems to be a safe limit if you have a healthy motor. Get a conseravtive tune and you'll be fine
Ruben...you're an idiot
Old Sep 17, 2006 | 08:37 PM
pearl's Avatar
cars lasted a long time buddy. big sc61 on 16-17 pounds. daily driven. making 300 whp too. someone needs to research before they run their mouth.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">Ruben...you're an idiot </TD></TR></TABLE>
Old Sep 17, 2006 | 08:47 PM
sherw00d's Avatar
Default Re: Boostin the ls (pearl)
o man
Old Sep 18, 2006 | 11:46 AM
91turboteg's Avatar
Default Re: Boostin the ls (adseguy)
So you say 300 whp is safe?
I rebuilt my engine last year, have less than 5000 miles on it
i just want to be sure.
thanks for all the help so far guys
Old Sep 18, 2006 | 03:21 PM
pearl's Avatar
i know 2 300whp LS motors. both have lasted.
300whp with a good tune.
NosBoost18ls
Jan 25, 2006 06:06 PM
budget
May 24, 2005 07:32 AM
xstalkrx
Jun 29, 2004 12:22 PM
ATYPR
May 21, 2002 01:26 PM
