VSS Problem
Old Sep 14, 2006 | 08:08 AM
BDBGoalie1982's Avatar
Default VSS Problem
Vehicle is a 1995 GSR.
Recently had an axle failure and afterwords the speedo cesed to function. I removed the VSS and I think it broke in half. All that is still on the bracket side is a little gold pin, with a notch on ethire side, that slides into a four-sided socket. There seems to be a broken circular piece in the opening on the transmission where the VSS mounts.
I have had no luck removing this with pliers, an suggestions on an easier method of removal?
Thanks in advance.
PsychoRex
Apr 26, 2012 07:23 AM
neldogg
Nov 17, 2007 05:09 PM
Joe...
Dec 29, 2006 06:54 PM
Turbocivic94
Apr 11, 2006 06:53 PM
J2turbo21
Mar 26, 2003 06:40 PM
