Werid Teg Problem
Old Sep 14, 2006 | 02:01 PM
IntegraGSR311's Avatar
Default Werid Teg Problem
Ok guys.. and girls here is the problem... please help!
Latley when i start my teg it has a really rough idle and needs to be reved up to get going but after it heats up its fine. Today it died at a stop light which it has been doing if its not warmed up. But when it died today it barley would start again and would idel really rough for like 5 seconds and die. So i replaced the fuel filter because we thought that may be the problem but after I did this it wont even start at all!!! Any thoughts? It has spark and im puttin in new plugs tommrow . Its just so weird because it started like 1 hour ago and now it just dosent catch. Thougths?
I also should mention that its turbo and was runnin about a quart and a half low on oil when it died earlier today
Please help Im stumped
Modified by IntegraGSR311 at 2:24 AM 9/15/2006
Modified by IntegraGSR311 at 2:27 AM 9/15/2006
Old Sep 14, 2006 | 02:09 PM
Lauj87's Avatar
Default Re: Werid Teg Problem (IntegraGSR311)
could be your dizzy going out. check your wires and injectors.
Old Sep 14, 2006 | 02:20 PM
OC Geezer's Avatar
Oil pressure maybe? Fuel pump not giving enough gas unless you rev and until it gets to OT.
Check your oil level haha.
Old Sep 14, 2006 | 05:24 PM
Default Re: (InLtegSra94)
any more thoughts? TTT ...also what is a dizzy
Old Sep 14, 2006 | 05:25 PM
trick_db's Avatar
Default Re: (IntegraGSR311)
DISTRIBUTOR
Old Sep 14, 2006 | 06:21 PM
Default Re: (trick_db)
I dont think its the "dizzy" bc it has spark. I think it is fuel because it wont rev up and when it dies it sounds like it just gets cut off. More thoughts?
Old Sep 14, 2006 | 08:46 PM
ttt
Mad Third Gear Vtec
Mar 25, 2009 09:20 PM
deadstock
Feb 5, 2009 09:04 AM
g2tegsown
May 17, 2008 08:09 AM
knightnam
Nov 2, 2005 06:32 AM
