s3 light blinking?
Old Sep 14, 2006 | 05:18 PM
frog169's Avatar
Default s3 light blinking?
i have a 92 Integra its an auto, for some reason the s3 light has been blinking, when it does the car wont start, and if it does start its as if it was stuck in 3ed gear. any one have an idea? a person who had hte same problem said take out the alt. fuse and put it in after 10sec should clear it but it didnt help. talked to a few others some said it might be a lock up solenoid, then a acura machanic said it might be a fuel relay. anyone have any clu how to trouble shoot it to see if it is or isnt a lock up or a fuel relay? ne info will help thanks.
Old Sep 15, 2006 | 04:48 PM
frog169's Avatar
Default Re: s3 light blinking? (frog169)
ne help?
Old Sep 15, 2006 | 05:01 PM
benjaminenjamin's Avatar
check your main relay. bad solder. its a black box thing. about 2" x 2" says "main relay" on it. should be in the driver side footwell area. above main fuse box. (with the ignition off and battery disconnected)find it, disconnect it, pry it open, very carefully drip a small drop of solder on each existing solder point, making sure not to allow any of the connections to touch each other. let it cool off, close it back up, reconnect the wiring connections, and hopefully it will fire right up.
if not, then youve got tranny probs. check that out. and then SEARCH
http://www.g2ic.com/forums/sho...20378
Old Sep 17, 2006 | 09:48 AM
integg93's Avatar
Default Re: s3 light blinking? (benjaminenjamin)
Were is the PA sensor located & how does it looks like i have a similar problem with a auto too.
Old Sep 17, 2006 | 10:27 AM
integg93's Avatar
Default Re: s3 light blinking? (integg93)
bump
f20cmx5
11
Mar 25, 2011 04:57 PM
Jenkinsal2
Mar 13, 2010 06:24 PM
battleREADYb20
Sep 9, 2006 07:46 PM
zCivic
Dec 15, 2005 08:00 AM
wu tang
Jun 12, 2002 10:47 AM
