intake manifold
Old 09-14-2006, 10:41 PM
4175017's Avatar
Default intake manifold
i am planning to swap my 2000 b16 head into my gsr block. should i use the gsr itm or use the si itm? which one is better?
Old 09-14-2006, 10:43 PM
Mr. green.'s Avatar
Default Re: intake manifold (4175017)
I'd use the b16 one.
Old 09-14-2006, 11:32 PM
qfast817's Avatar
Default Re: intake manifold (L33T)
the gsr wont work with the si head, you could get a type r or buy a used skunk2 for the same price.
Old 09-15-2006, 06:17 AM
mr.beeks's Avatar
Default Re: (z51C6)
gsr and si intake mani are not intercheangeable.
and on a good note both mani are great designs.
only good reason to change to type R or skunk2 if you are seriously hitting higher RPM's
Old 09-15-2006, 06:19 AM
lVlemphizStylez's Avatar
Default Re: (mr.beeks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks &raquo;</TD></TR><TR><TD CLASS="quote">gsr and si intake mani are not intercheangeable.
only good reason to change to type R or skunk2 if you are seriously hitting higher RPM's</TD></TR></TABLE>
you could say that till youre blue in the face...itll never stick...Stock is associated with bad...Bigger is associated with better (REGARDLESS of the working environment)
Old 09-15-2006, 11:37 AM
VTECth1s's Avatar
b16 you can not use at all, any b18c IM wont bolt up to the b16 head, the bolt pattern is different. You can only use a b16 or b18c5 IM, or an aftermarket such as skunk 2, blox, aeb...etc.
EgxHaTcHxGsR
03-22-2019 11:35 PM
erickrodriguez
Northeast (Sales)
04-02-2010 06:50 PM
Elite2000
07-10-2009 02:34 PM
nuklang
10-02-2006 04:57 PM
maka
03-25-2005 06:00 AM
Quick Reply: intake manifold
