Ls vtech
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Backk InTheDA »</TD></TR><TR><TD CLASS="quote">Get the GSR head and build it. No point in getting the type R head, if you plan to go boost, compression is a little high for that.</TD></TR></TABLE>
haha what? the head has too high compression?
because actually by using a GSR head you will raise the compression more than with a type r head because of the size of the combustion chamber
and FYI there are advantages to a type r head other than the name
because actually by using a GSR head you will raise the compression more than with a type r head because of the size of the combustion chamberand FYI there are advantages to a type r head other than the name
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcMONSTER »</TD></TR><TR><TD CLASS="quote">
haha what? the head has too high compression? because actually by using a GSR head you will raise the compression more than with a type r head because of the size of the combustion chamber
and FYI there are advantages to a type r head other than the name </TD></TR></TABLE>
thats the same thing i was thinking. i was like WTF?!? to the OP, i would recommend u don a shitload of reasearch and thinking before u attempt ur ls/vtec. then once u have somewhat of a feel for hondas then maybe attempt it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18B1_4DR »</TD></TR><TR><TD CLASS="quote">b16.</TD></TR></TABLE>
WTF?
WTF?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW_98gsr »</TD></TR><TR><TD CLASS="quote">
WTF?</TD></TR></TABLE>
he prolly said b16 1) flow characteristics 2) price & availabilty
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vybez64 »</TD></TR><TR><TD CLASS="quote">I have a Ls and want to go vtech </TD></TR></TABLE>
hello! its VTEC.......NOT vtech omg &^%$#*(~!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vybez64 »</TD></TR><TR><TD CLASS="quote"> need some help what will work better 4 me GSR or Type R. </TD></TR></TABLE>
go NSX
go NSX
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAmodified »</TD></TR><TR><TD CLASS="quote">b16 head is better then gsr head.</TD></TR></TABLE>
enligthen everyone as to why you think this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red eye teggy »</TD></TR><TR><TD CLASS="quote">
go NSX
i heard the honda inasight head has a strong vtec
go NSX
</TD></TR></TABLE>i heard the honda inasight head has a strong vtec
u must first need a brain for the head u need. then put it to work. be smarter next time and use the search buttons. i see these damn threads almost everyday and it gets annoying
And I am sure you have some good solid information to back up this "opinion"?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vybez64 »</TD></TR><TR><TD CLASS="quote">I have a Ls and want to go vtech, need some help what will work better 4 me GSR or Type R. </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1676914 pretty much all you'll need for the LS Vtec set up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dartanian »</TD></TR><TR><TD CLASS="quote">
And I am sure you have some good solid information to back up this "opinion"?</TD></TR></TABLE>
i wanna know too..
i wanna know too..
I would say in stock form the the B16 head is better than the GSR head, but if you get head work done, then either one would be good. Just my opinion and if I remember right, the B16 is almost like the ITR with out the factory port and polish...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAmodified »</TD></TR><TR><TD CLASS="quote">b16 head and type r head are the same other then the type r has a port polish, valve job and better cams. b16 head is better then gsr head.</TD></TR></TABLE>
ok ill provide some info on this. in a sense, one of the heads is not better than the other. but, what i can tell u is a reputable head porter (i wanna say rlz) put a stock b16 head and a stock gsr head on a flowbench and the b16 flowed roughly 5 more cfm. not much of a difference but it does flow a tiny bit better. in my own opinion, i think both heads are about equal cause the majority of us that build motors dont keep our motors stock and end up putting in cams, port/polish, etc.
also, b16 and itr are not the same head. they are made from the same casting but the itr has different valvetrain, different cams, a better im, bigger tb, and a factory port job
