help!! ball joint REMOVE
Old Jan 19, 2007 | 03:04 PM
Silent_Destruct's Avatar
Default HELP NEED FAST!! ball joint REMOVE
ok i have it loose and out of the control arm and i have the axle off, but i want to REMOVE the ball joint completly....ive been banging on it for an hr now and nothing. HELP!!!
Modified by Silent_Destruct at 6:21 PM 1/19/2007
Old Jan 19, 2007 | 03:32 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: HELP NEED FAST!! ball joint REMOVE (Silent_Destruct)
I assume this is the lower balljoint. Have you tried heating the knuckle? (Protect the brake and ABS lines, etc.)
Old Jan 19, 2007 | 03:53 PM
yes lower ball joint, i have nothing to heat it with though
Old Jan 19, 2007 | 04:40 PM
cant get ball joint out!!!! have heated it an everythinga nd nothing!
Old Jan 19, 2007 | 06:08 PM
TurboTeG4's Avatar
Default Re: (Silent_Destruct)
Depending on where you heat it, it will cause the greese inside to expand and will explode the ball joint apart with enough force to break open your skull, or seriously wound anyone it makes contact with.
Old Jan 20, 2007 | 04:24 AM
Sam92Teg's Avatar
Did you remove the C-clip?
Old Jan 21, 2007 | 07:21 AM
Old Jan 22, 2007 | 12:49 AM
hionvtecxda6's Avatar
Default Re: HELP NEED FAST!! ball joint REMOVE (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">Did you remove the C-clip?</TD></TR></TABLE>
what he said..
Old Jan 23, 2007 | 08:50 AM
Bricksta's Avatar
There is a special tool to get that out.
you have to go to a shop and talk to them
Old Jan 23, 2007 | 11:52 AM
DC2_005200's Avatar
way i take them out is spray wd-40 on everyting around it and then banging it on the side of the cast iron where the ball joint. DO NOT HIT THE TREAD OF THE BALL JOINT THO. i means beat the **** out of this iron and it pops out....also helps if you have someone lifting up and down on the hub itself
Old Jan 23, 2007 | 12:08 PM
wrx'n you's Avatar
Default Re: (DC2_005200)
i got mine out by going to autozone. they have a free rental program there, well actually u gotta pay but u get all ur money back when u return the tool. its basically a big *** C-clamp. either that or bang the hell out of it.
ZOMBIEKILLER
Suspension & Brakes
11
Feb 24, 2008 05:51 PM
rasinhell
32
Jan 17, 2005 04:57 PM
2camsaam
Oct 2, 2003 07:30 AM
accordfreak
Jul 11, 2003 10:17 AM
Flamenco-T
Aug 21, 2002 11:49 PM
