Testing Injectors
Old Jan 21, 2007 | 11:35 AM
Dealer Leaf's Avatar
Default Testing Injectors
Is there any easy way of testing to see if my injectors are working. I know there getting signal ive tested that but dont know if there working.
Right now im about to switch the injectors around to other cylinders that are working and if the problem follows then its the injectors.
Old Jan 22, 2007 | 09:09 AM
sneakysneaky's Avatar
Default Re: Testing Injectors (Dealer Leaf)
the easiest way is to go to the junk yard and clip an injector harness.
you then find a 9v battery terminal out of one of your kids broken toys.
solder the two together. walla when you connect the harness up injector
will be wide open. spray carb cleaner through it with one of the straw on the can
and you will see if it opening or not.
JDM C.A.R
13
May 10, 2010 07:30 AM
fortynineR
Aug 30, 2007 03:08 PM
c1civic
Dec 12, 2006 07:31 PM
