WOULD it work?
Old Jan 23, 2007 | 03:44 PM
kamakaze1's Avatar
Default WOULD it work?
have a 95'GSR chassis,would the red valve cover H22(TYPE S/R)i think it's rated 220hp/165tq to the crank,one of those work in my car.heard that the single plenum intake manifold H22 would be difficult to wire up for some odd reason.....................could anybody out there help out with this INFO!
Old Jan 23, 2007 | 04:16 PM
numbnuts22715's Avatar
of course it can work, its just a lot of trouble.
If you havent done a swap before, I wouldnt recommend trying it.
Post up on the hybrid forum, Im sure someone there could tell you exactly how hard it is.
Old Jan 23, 2007 | 05:38 PM
slowb20boost's Avatar
Default Re: WOULD it work? (kamakaze1)
no
Old Jan 23, 2007 | 06:38 PM
JiZzEr's Avatar
Default Re: WOULD it work? (slowb20boost)
with hasports motor mounts it should fit ive seen dc2's with h22 turbo
Old Jan 24, 2007 | 05:07 AM
kamakaze1's Avatar
Default Re: WOULD it work? (jizzer)
well i've done practically every swap in every year honda,and i've done several H22 swaps in integra's,i just heard that there's a couple of things that would be difficult to wire up.....................
Old Jan 24, 2007 | 05:13 AM
kulrevon's Avatar
the had thing to wire up is the iac. I believe it has a three wire. and normal hondas have a two. You just need an adapter plate and you can use the 2 wire iac. Its not that difficult.
iwanttokillgod
Dec 19, 2008 08:24 PM
kamakaze1
Feb 1, 2007 05:00 PM
turtleman321
Nov 4, 2006 07:19 PM
tr0n9h
Oct 7, 2005 05:17 PM
Maddox
Apr 27, 2004 10:46 AM
