HELP. please
Old Jan 20, 2007 | 12:27 PM
JDM-ish's Avatar
Default HELP. please
k i need ur guys help. my LS tranny. well there are times when i can drive good and its werking very well. but there are other times where i just cant shift at all. its just stuck there in neutral no matter how hard i pull it into gear. BUT i can power shift it. and when i am stopped and put it in gear the car starts moving on its own and dies out right after. whats wrong with my transmission? please help thanks :D
Old Jan 20, 2007 | 01:19 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: HELP. please (wholikerace.)
It sounds like the clutch is not disengaging. When this problem occurs, can you shift gears with the engine off?
Check you fluid level in the clutch master cylinder.
Old Jan 20, 2007 | 01:25 PM
JDM-ish's Avatar
[quote]It sounds like the clutch is not disengaging. When this problem occurs, can you shift gears with the engine off?
Check you fluid level in the clutch master cylinder. [\quote]
i changed the master cylinder. and when the engine is off i can shift thru gears. i also changed the throwout bearing. but after all taht its still doing it. could it possibly be my clutch?
Old Jan 20, 2007 | 02:22 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (wholikerace.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wholikerace. &raquo;</TD></TR><TR><TD CLASS="quote">i changed the master cylinder. and when the engine is off i can shift thru gears. i also changed the throwout bearing. but after all taht its still doing it. could it possibly be my clutch?
It could be the clutch. Have you bled the clutch slave cylinder thoroughly?
Old Jan 20, 2007 | 03:07 PM
JDM-ish's Avatar
Default Re: (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
It could be the clutch. Have you bled the clutch slave cylinder thoroughly?</TD></TR></TABLE>
yeah we changed the clutch slave cylinder as well.. one of my frends was telling me something about the fork in the tranny or someting? i dont know but much help is needed.
Old Jan 20, 2007 | 05:49 PM
JDM-ish's Avatar
com'on! somebody has to know the problem. i really need to get this car running good.. this is my daily driven car.
Old Jan 20, 2007 | 05:52 PM
youdontknowmeeither's Avatar
throwout bearing?
99hondadx
Feb 10, 2017 05:35 AM
kinoy12
Acura TSX
Dec 1, 2015 10:13 AM
jdm_phunk
Feb 27, 2011 05:17 PM
flatblack-h22
Transmission & Drivetrain
Jan 18, 2009 05:12 AM
del_parker
Sep 1, 2003 07:17 PM
