piston/bore ???
Old Jan 21, 2007 | 02:47 PM
DB1_559's Avatar
Default piston/bore ???
im looking to put higher comp pistons on my b18a but want to keep the 81mm bore.Have anyone kept the stock bore without any problems etc
Old Jan 21, 2007 | 02:51 PM
dohcMONSTER's Avatar
Default Re: piston/bore ??? (jdmboi86)
yea just throw in some pr3's or p73's with a fresh hone and new rings
Old Jan 21, 2007 | 03:17 PM
sdr KEL's Avatar
Default Re: piston/bore ??? (dohcMONSTER)
why not bore it .5 more 81.5mm
Old Jan 21, 2007 | 03:45 PM
doood's Avatar
been there done that
Default Re: piston/bore ??? (sdr KEL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sdr KEL &raquo;</TD></TR><TR><TD CLASS="quote">why not bore it .5 more 81.5mm </TD></TR></TABLE>
that extra .5 isnt going to make much of a difference. only overbore if you need to get the cylinders back to round.
Old Jan 21, 2007 | 05:14 PM
DB1_559's Avatar
Default Re: piston/bore ??? (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">
that extra .5 isnt going to make much of a difference. only overbore if you need to get the cylinders back to round.</TD></TR></TABLE>
oh yea so i dont have to bore it out i can just throw some p30 pistons in and call it a day
Old Jan 21, 2007 | 05:37 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 &raquo;</TD></TR><TR><TD CLASS="quote">
oh yea so i dont have to bore it out i can just throw some p30 pistons in and call it a day </TD></TR></TABLE>
it's not that simple either. depending on the condition of the cylinders you may have to overbore. if not, then a re-hone may be necessary. either way you should replace the bearings since you have everything apart.
Old Jan 21, 2007 | 10:31 PM
DB1_559's Avatar
it's not that simple either. depending on the condition of the cylinders you may have to overbore. if not, then a re-hone may be necessary. either way you should replace the bearings since you have everything apart.</TD></TR></TABLE>
oh yea i know but will the rehone keep the stock 81mm trying to stay at 81mm at most
pornstar4777
Feb 14, 2008 12:47 PM
garyc17
Jun 12, 2007 02:26 AM
Modern91Hatch
Jul 13, 2006 02:57 PM
Hockey27925
Jan 30, 2005 07:47 AM
hondaguyef
Jul 8, 2004 02:51 AM
