Pistons replacement
Old Jan 22, 2007 | 10:51 AM
qazaq's Avatar
Default Pistons replacement
i'm moving from suspension to the engine soon, so first thing i want to do is stop oil burning so i want to get some new seals and piston rings ,new pistons as well
which parts do i need to get from this list to replace pistons and rings:
13010-P54-000 PISTON SET (STD)
13020-P54-000 PISTON, SET (OS 0.25)
13011-PR3-003 RING SET, PISTON (STD) (TEIKOKU)
13021-PR3-003 RING SET, PISTON (OS 0.25) (TEIKOKU)
13021-PR3-004 RING SET, PISTON (OS 0.25) (RIKEN)
13112-P3F-000 PIN, PISTON
and seals:
12210-PT2-003 SEAL A, VALVE STEM (ARAI)
12210-PT2-004 SEAL A, VALVE STEM (NOK)
12211-PT2-003 SEAL B, VALVE STEM (ARAI)
12211-PT2-004 SEAL B, VALVE STEM (NOK)
Old Jan 22, 2007 | 12:29 PM
Fat Chick Magnet's Avatar
you need OEM STD piston rings/seals for stock gsr pistons. unless your going with high compression pistons.
Old Jan 22, 2007 | 02:34 PM
qazaq's Avatar
Default Re: (dc2rtek)
(ARAI) and (NOK) is that a type of seals or just different brands
Old Jan 22, 2007 | 02:37 PM
doood's Avatar
been there done that
Default Re: (qazaq)
looks like different brands
Old Jan 22, 2007 | 02:43 PM
qazaq's Avatar
Default Re:
that's what i think too. but im not sure tho
so all i need is this rite?:
pistons:
seals:
or
if this is correct can somebody plz confirm so i wouldn't end up buying wrong parts
Old Jan 22, 2007 | 05:51 PM
qazaq's Avatar
Default Re: Re: (qazaq)
anybody?
JDM-EJ698
Apr 23, 2009 06:29 PM
boostedb20z
Feb 10, 2008 12:38 PM
RACEPAK
Oct 15, 2007 06:00 AM
oxSLEEPERxo
Jun 25, 2007 08:35 AM
int3gra
May 23, 2002 03:30 PM
