Axle question!
Old Jan 22, 2007 | 10:16 PM
suken19's Avatar
Default Axle question!
Ok, this may sounds stupid but I just want to make sure. I have a 99 GS with 157K miles on it. Should I change the axles on the car? I remember my 89 accord with 199K axle went out on me. Can an axle fall apart while driving or broke off? Scary **** whenever I think about stuff like this but I just want to make sure.
Thanks for any help!
Old Jan 23, 2007 | 09:22 AM
95 integra's Avatar
Default Re: Axle question! (suken19)
Fall apart? No likely....break, yes....but not likely on stock hp. Just get them rebooted and regreased and you'll be fine.
Old Jan 23, 2007 | 12:31 PM
pennies_hatchie's Avatar
Default Re: Axle question! (95 integra)
i would just check them for leaks (tears in the boot/grease all over) and check to see if cv joints are clicking. if none of the above then your axles are still good
Old Jan 23, 2007 | 04:18 PM
Brick Top's Avatar
Default Re: Axle question! (pennies_hatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennies_hatchie &raquo;</TD></TR><TR><TD CLASS="quote">i would just check them for leaks (tears in the boot/grease all over) and check to see if cv joints are clicking. if none of the above then your axles are still good</TD></TR></TABLE>
ya. no reason to be paranoid about them unless your experiencing these symptoms.
Old Jan 23, 2007 | 06:03 PM
KPGzDA's Avatar
My Cv joints click when i turn hard to the right or the left so that means my axles are going right and i also see a little leak coming from right under the
Old Jan 23, 2007 | 09:39 PM
suken19's Avatar
Default Re: Axle question! (brick top)
Thanks for all the help guys! I feel much better now!
jonyi27
Nov 23, 2012 07:47 PM
tamadrummer1120
Oct 13, 2009 07:48 AM
b16aej6
Jan 29, 2008 10:27 AM
whatsthatnoise
Oct 10, 2006 03:09 PM
nonvteclude
Aug 7, 2006 08:45 PM
