wiring help!
one night i was drivin my 99 LS and when i got home i noticed my runnning light(tail lights, corners and license plate lights were all off) so i checked all the bulbs and they worked fine. My turn signals and brake lights both worked fine so i replaced the fuses for the running lights. I replaced it about 5 times but everytime i tried to turn them on again the fuse blew immediately....wat could my problem be?
bad wiring (grounding out somewhere). You can try using a fuse 5 amps larger then the stock one and see if it blows (ONLY use one 5 amps larger, going beyond that results in melted wires and all kinds of good stuff). If the larger one blows its a ground problem.
ok so i tried using the larger fuse, and the running lights flickered on for a split second then shut off again like the fuse blew.....only this time the fluse didn't blow!? the bulbs and connections are good and i replaced the fuse with at least 3 other ones and neither of them blew....please help!
thisboyjulio
Nov 10, 2008 03:50 PM
Joey B 18C
Feb 18, 2005 06:58 AM
