ABS Problems....help please!!!
Old Jan 22, 2007 | 04:00 AM
Kentagious's Avatar
Default ABS Problems....help please!!!
I've got a '95 GS-R. for some weird reason...my ABS light comes on every other time I start and drive the car. I can't figure out why...any ideas???
Thanks
Old Jan 22, 2007 | 04:49 AM
Rahxephon's Avatar
Default Re: ABS Problems....help please!!! (Kentagious)
i have the same problems...trying to get the trouble codes first...that's what i'm going to do first.
Old Jan 22, 2007 | 06:20 AM
JasonST's Avatar
Default Re: ABS Problems....help please!!! (Rahxephon)
U can check the code it gives u the same way u woul check the check engine light code.
Old Jan 22, 2007 | 06:52 AM
black_cap's Avatar
Default Re: ABS Problems....help please!!! (JasonST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonST &raquo;</TD></TR><TR><TD CLASS="quote">U can check the code it gives u the same way u woul check the check engine light code.</TD></TR></TABLE>
Do this first, then we can help you further.
Old Jan 22, 2007 | 10:32 AM
sabotage7's Avatar
Default Re: ABS Problems....help please!!! (black_cap)
+1, i'm going thru the same thing. let us know what the code is....
on mine, i got the code 1-8 and called a buddy at the dealer w/the info and he said something for me to try is to remove the fluid from the abs reservior and put new in and go out and "exercise" my car by making the tires slide and what not. he said to flush the fluid and "exersice" it a couple times as there may be some debrise in there that could losen up. so i managed to get the brake fluid out, which looked brand new btw there wasnt any dirt in there, and i took her autoxing in my neighborhood in an unfinished section. well i did that and its still the same. =/ i didnt do it a 2nd time though as i ran out of time. he said he could hook it up to something at the dealer and try that too. he said about 50% of the time it works. good luck!
Old Jan 23, 2007 | 06:35 AM
sabotage7's Avatar
Default Re: ABS Problems....help please!!! (sabotage7)
oh yeah, and i forgot to mention one of my findings....that when my abs light is not on, my abs works. when its on, it doesnt work.
Old Jan 23, 2007 | 07:19 AM
Rahxephon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sabotage7 &raquo;</TD></TR><TR><TD CLASS="quote">oh yeah, and i forgot to mention one of my findings....that when my abs light is not on, my abs works. when its on, it doesnt work. </TD></TR></TABLE>
but that's normal...
Old Jan 23, 2007 | 07:56 AM
jonshonda's Avatar
Community Builder
I had a problem with my abs on my 95 Gsr also, I just pulled the fuse for the abs, and have left it ever since. I have never had abs on any of my cars, and really don't need it cuz I don't drive it in the snow anyways. Honeslty, I am planning on just taking all of the abs equipment out and going with the RS braking setup which eliminates the abs system. ABS FTL
Old Jan 23, 2007 | 07:58 AM
mike-y's Avatar
does the ABS pump cycle when it turns on? it should only cycle for a few seconds. My ABS pump had a slow leak, and would cycle longer and longer until I refilled the ABS resevior. The leaking fluid would eat up the paint on the frame rail though, so I just ended up pulling the ABS fuse.
Old Jan 23, 2007 | 11:26 PM
Kentagious's Avatar
Default Re: ABS Problems....help please!!! (mike-y)
My ABS does cycle when it turns on...I'll have to try that cycling thing. How do I check the codes???
Old Jan 24, 2007 | 05:27 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kentagious &raquo;</TD></TR><TR><TD CLASS="quote">My ABS does cycle when it turns on...I'll have to try that cycling thing. How do I check the codes???
There is a link in the Integra FAQ thread.
Old Jan 24, 2007 | 06:31 AM
black_cap's Avatar
https://honda-tech.com/zerothread?id=978933
Old Jan 24, 2007 | 07:06 AM
bshshondaman06's Avatar
the leaking modulator is very common for our integras. i have a 96 that had a leaky modulator or pump. its about 1300 to fix.
EG8B16
Feb 9, 2016 07:51 PM
eg_boi
Aug 4, 2008 01:12 PM
anonchild
Feb 20, 2006 05:13 AM
egsauce
Aug 17, 2005 09:39 PM
VTECAcuraGSR
Aug 18, 2002 03:33 PM
