question???
Old Jan 29, 2007 | 06:14 AM
frankenstienEk's Avatar
Default question???
got my timing belt replaced about 10 thousand miles ago but dident change the cam seals at the time because they looked fine. Now one of them is leaking, to replace them do i have to loosen the tensioner to have some slack on the belt then take of the cam gear or can i just loosen the cam gear and slide it off the belt? thanks
Old Jan 29, 2007 | 07:29 AM
Default Re: question??? (frankenstienEk)
anybody?
Old Jan 29, 2007 | 12:02 PM
autopro01's Avatar
the cam seal is on the left side not the side with the belt. and to change it u have to take the valve cover off and loosen the cam cap that the cam seal is inside of. pull it out and put the new one in and tighten cap to 21 ft pounds put valve cover back and everything else and ur done. if u have any more ? write back
Old Jan 29, 2007 | 01:13 PM
Default Re: question??? (autopro01)
Not too sure what there called cam seals, camshaft seals their seals that sit behind the cam gears. Somebodys gotta know what am talking about, I might of named it wrong but, Thought i made myself clear when i was explaining it in the area that they would be located in.
Old Jan 29, 2007 | 04:37 PM
Dogginator's Avatar
Daisy... Daisy...
You will need to loosen the timing belt, and remove the cam gear, etc. This is a diagram from a DC2. The seals are part #24.
http://www.acuraparts247.com/p...ch=no
Old Jan 29, 2007 | 05:30 PM
Default Re: question??? (Dogginator)
thanks for the help
Old Jan 29, 2007 | 05:31 PM
sorry meant
Old Jan 29, 2007 | 10:33 PM
youdontknowmeeither's Avatar
i don't think the cam caps get tightened to 21 ft/lbs. i thought it was 76 inch/lbs or something like that...
MR Rodgers
Jun 26, 2007 09:46 PM
4DRmafia
Dec 22, 2005 08:45 PM
EJ8tunerman
Jun 21, 2005 04:35 PM
HamiltonRex
Nov 13, 2004 05:50 PM
out2wincrx
Mar 13, 2002 11:47 PM
