A/C help please
Old Apr 5, 2007 | 08:10 AM
Spoogen_1's Avatar
Default A/C help please
I know exaclty what is wrong but i dont know how to fix it. Maybe you can.
The other day I unhooked the little piece of metal wire with the loop for the climate control. I had planned to take it out thats y. But after a few minutes of trying to get the buttons out i sed F this and poped the wire thingy back in where it was. Since then when I drive alittle bit of air goes threw my air vents as if the little a/c dorr is slightly open. even tho the air is off. But when i turn the air on it blows alot better now. How do I adjust it again so the air doesnt sneak threw. I know the wire shouldnt really effect anything but I wanted to mention it just incase. thanks
Old Apr 5, 2007 | 08:12 AM
Schister66's Avatar
Man U FTW
my vents never shut all the way and i get a breeze through the car no matter what i try...i thought it was normal
Old Apr 5, 2007 | 08:13 AM
numbnuts22715's Avatar
a little bit has always came through on my a/c...
just a tiny bit.
Do you have it on recirculate? If it isnt, it will blow out a little bit more than when you have it on recirculate, if the a/c is off.
Old Apr 5, 2007 | 09:42 AM
rocklobsta's Avatar
Default Re: A/C help please (Spoogen_1)
so your saying that the ac is on? im confused..the vents should always moving some air even when the blower is off. they do it so that fresh air is always entering the cabin, preventing the air in the cabin from getting stale..if im wrong someone else chime in
Old Apr 5, 2007 | 09:46 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If the car is moving, and the climate control is set to fresh air intake, then some air will always come through the vents, even with the fan off (even more air if the sunroof is popped open). If you set the climate control to recirculate, the little damper under the cowl area will move to shut off the opening for fresh air intake.
It all sounds normal to me, if it's operating like I described. Although I'm not sure what this "wire loop" thing is that you described.
Old Apr 5, 2007 | 07:24 PM
Spoogen_1's Avatar
Default Re: (PatrickGSR94)
I guess maybe its just doing it more so I maybe didnt notice before. But if its normal then I guess I wont have to worry bout nothing. Thanks
cloudbreakmd
Feb 12, 2009 02:25 PM
NoEx00
Mar 8, 2007 07:31 PM
superboss
Jan 22, 2007 11:26 PM
IgniteTeg
Jun 7, 2002 05:49 AM
