temperature gauge increases randomly
Old Apr 2, 2007 | 10:04 PM
NAmodified's Avatar
Default temperature gauge increases randomly
i have a 99 dc2 with a aluminuim radiator and spoon rad. cap... I noticed my temp gauge increase to about 3 quarters of the temp gauge for a short period of time and then it goes back down to its normal temp. This only happens once in a while, but i dont want it leading to something worse. Is there anyone that may know my problem.
Old Apr 2, 2007 | 10:09 PM
bsdc2's Avatar
Default Re: temperature gauge increases randomly (NAmodified)
faulty gauge?
Old Apr 3, 2007 | 03:58 AM
-Kirk-'s Avatar
A friend of mines car would do that all the time. The gauge would read about 3/4 up at random times and then drop right down to normal. We finally decided it was the gauge after checking and replacing everything cooling related.
Old Apr 3, 2007 | 08:05 AM
NAmodified's Avatar
Default Re: temperature gauge increases randomly (-Kirk-)
yea the gauge has always worked fine. could it be my thermostat? any other thoughts?
Old Apr 3, 2007 | 09:03 AM
-Kirk-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAmodified &raquo;</TD></TR><TR><TD CLASS="quote">yea the gauge has always worked fine. could it be my thermostat? any other thoughts?</TD></TR></TABLE>
I'd definitely replace it if you haven't. It might be opening too late. Even if it's not the problem you won't be out much money replacing it.
Old Apr 3, 2007 | 11:09 AM
NAmodified's Avatar
replace the gauge or the thermostat?
Old Apr 3, 2007 | 12:54 PM
thewrai6th's Avatar
Thermostat first. Maybe it's opening late, or is dirty or stuck. It's easy and cheap.
I once found a screw holding mine open (previous owner, maybe on purpose). The car would stay in rich-warm up mode for an hour.
Other than that, I would check for air in the system.
Old Apr 3, 2007 | 02:08 PM
-Kirk-'s Avatar
Default Re: temperature gauge increases randomly (thewrai6th)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thewrai6th &raquo;</TD></TR><TR><TD CLASS="quote">Thermostat first. Maybe it's opening late, or is dirty or stuck. It's easy and cheap.
Other than that, I would check for air in the system.</TD></TR></TABLE>
Yeah, I meant the thermostat first since it's a cheap part. Air in the system is also a likely culprit.
Dmascarenasp
Honda Civic (2001 - 2005)
Mar 14, 2016 11:15 AM
robtackett
Oct 21, 2005 07:35 PM
Boofster
Dec 6, 2004 03:18 PM
