(searched) stock b18b compression ratio?
Hype-R Stalker
Re: (searched) stock b18b compression ratio? (youknowimwhite)
145Hp 127Trq 9.4 Compression (JDM)
142Hp 127Trq 9.2 Compression (USDM)
Pulled the numbers off of hmotorsonline.
been there done that
are you doing a compression or leakdown test?
a compression test the numbers themselves arent as important as the numbers from each cylinder being within 10-20psi of each other. just make sure you do the test with the engine warm and throttle wide open.
