eng fan problem
Old Apr 5, 2007 | 06:21 AM
hondateg10's Avatar
From: Somewhere in the United States, united states
Default eng fan problem
ok i have a 90 integra with a b16a swap. my eng fan is not kicking on. does ne one know how i can hot wire it to a switch but not make it look ghetto and how i can do it???
Old Apr 5, 2007 | 07:35 AM
Sam92Teg's Avatar
Default Re: eng fan problem (hondateg10)
First take a jumper wire to the fan switch to see if it kicks on, if it does, all you need is a new fan switch. If you don't want to buy a fan switch, just tape up the jumper wire and it will stay on.
If the fan doesn't turn on when you jump the fan switch, take a jumper wire directly to the fan and see if the fan isn't burnt out itself. If it works, then your relay or wiring should be checked.
As for a switch, many have done it, but do you really want to take a chance of forgetting to turn it on and burning up your engine? A simple search should tell you how to wire it, this has been covered.
Old Apr 5, 2007 | 07:44 AM
hondateg10's Avatar
ok i have taken a jumper wire from the switch straight to the battery and the fan comes on!!! so your saying i need a new switch?
Old Apr 5, 2007 | 08:20 AM
hondateg10's Avatar
ttt
Old Apr 5, 2007 | 08:29 AM
IN VTEC's Avatar
Default Re: (hondateg10)
Check the fan fuse in the engine bay fuse box. It's the 20A fuse next to the back-up fuse, closest to the windshield cowl.
Old Apr 5, 2007 | 08:34 AM
hondateg10's Avatar
so even if thats blown the fan will come on when i jump it straight to the battery
1uncleanDA's Avatar
Default Re: (IN VTEC)
Mine never goes on....no over heating problems here
Old Apr 5, 2007 | 08:41 AM
hondateg10's Avatar
Default Re: (1uncleanDA)
so your thinking i got another problem
killaberna
Sep 14, 2015 10:06 AM
98ej8coupe
Jul 30, 2008 10:07 PM
4DRmafia
Sep 1, 2004 02:59 PM
dingusjt
Jul 15, 2002 10:40 AM
94hondacivic
Aug 30, 2001 10:48 AM
