how bad ????? HELP!
Old Apr 3, 2007 | 04:48 AM
lilpastrana's Avatar
Default how bad ????? HELP!
ok bought my dx swap with a " supposibley a 1989 ls swap" NON sense, guess there is no b18a made in 89 bullshit. so i bought the car and didnt change the oil cause i knew the kid and it was changed before i bought it. so of course its a honda i check the oil more then evertime i fill up. well the oil light has been on a lot. brother is driving the car to school hears the engine making weird noise. stops pulls over drives back home a couple miles away. ends up draining oil, only about 1.5-2 quarts with a TON of metal in there. Turns out there is a wrong dipstick on there and we've been runing low on about 1-3 quarts for the past 3-5 weeks. the noise was a rod bearing. that we have out and orderd new ones. what are the chances we can put new rod bearings in and keep driving it with the right amount of oil ? and everything is orange if u look up at the motor from under the car.
Old Apr 3, 2007 | 06:23 AM
Default Re: how bad ????? HELP! (lilpastrana)
bump
Old Apr 3, 2007 | 06:35 AM
Lewy. Dee Ayy's Avatar
get the right dip stick?....and ur motor is orange!? jdm as fawk.
Old Apr 3, 2007 | 04:34 PM
Default Re: how bad ????? HELP! (Lewy. Dee Ayy)
yeah ur dumb.
Old Apr 3, 2007 | 07:04 PM
doood's Avatar
been there done that
the rod journals on the crank could have been scratched. if that happend you'll need a new crank.
Old Apr 3, 2007 | 07:12 PM
CleanLikeJdm's Avatar
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilpastrana &raquo;</TD></TR><TR><TD CLASS="quote">yeah ur dumb.</TD></TR></TABLE>
Nice reply
IF you had a spun bearing, you would know it, because rodknock is not easily overlooked.
And goodluck on swapping out a new bearing ..
There is a LOT more work behind it depending on how long you ran without a bearing on that journal,
Your crank could be fucked enough that it can't be resurfaced either,
which it's not even that cheap to have done in the first place.
But to have to go with a new crank, you're better off getting a new motor.
Old Apr 3, 2007 | 08:35 PM
401tuner's Avatar
Default Re: how bad ????? HELP! (CleanLikeJdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm &raquo;</TD></TR><TR><TD CLASS="quote">
But to have to go with a new crank, you're better off getting a new motor.</TD></TR></TABLE>
agreed
Old Apr 3, 2007 | 08:43 PM
1998b18c1's Avatar
Nice reply
new motor.....replacing bearings not worth the time. agree with cleanlikejdm
Old Apr 3, 2007 | 09:52 PM
MatrixGSR's Avatar
Default Re: how bad ????? HELP! (401tuner)
Disagree... new motors can cost a crap load. I'd go as far to say a good shape crank for $150 and new bearings and stuff (possibly new rod) for less than $300... $450 &lt; $1000+ for a new motor.
Old Apr 3, 2007 | 09:58 PM
doood's Avatar
Default Re: how bad ????? HELP! (MatrixGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MatrixGSR &raquo;</TD></TR><TR><TD CLASS="quote">Disagree... new motors can cost a crap load. I'd go as far to say a good shape crank for $150 and new bearings and stuff (possibly new rod) for less than $300... $450 &lt; $1000+ for a new motor. </TD></TR></TABLE>
dont forget to add in labor charges. it's gonna add up.
on the other hand you can find a b18a shortblock for cheap and swap it in with relative ease.
1000+ for a new LS? is it made from gold?
Old Apr 3, 2007 | 10:35 PM
MatrixGSR's Avatar
find me a BRAND NEW LS motor for under $1000 and i'll gladly take back that comment. I'm not referring to previously used swaps, I've seen them on ebay for $600 (long block).
Old Apr 4, 2007 | 04:46 AM
well new bearing are already in said it was a peice of cake. but there is still a very small knock. thinking that there was wear on the journal and it is from the rod/ bearing.
Old Apr 4, 2007 | 03:27 PM
doood's Avatar
you put in new bearings without touching the crank?
Old Apr 4, 2007 | 05:36 PM
Hype-R Stalker
Default Re: how bad ????? HELP! (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">you put in new bearings without touching the crank? </TD></TR></TABLE>
lol.. x2
Ouch?
Old Apr 4, 2007 | 05:38 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm &raquo;</TD></TR><TR><TD CLASS="quote">lol.. x2
Ouch?</TD></TR></TABLE>
expensive ouch
Old Apr 5, 2007 | 05:21 AM
30 dollars we do all work ourselves so no labor charges. and we are getting new rods, bearings, possibley pistons and a new crank. engine is getting pulled as soon the freakng rear lca's come in for my gsr thats in the garage.
Old Apr 5, 2007 | 08:16 AM
Tyounin608's Avatar
I would just bank that biatch off the rev limiter until it blows then buy a b18c5
Old Apr 5, 2007 | 10:01 AM
Default Re: how bad ????? HELP! (Tyounin608)
ahhh that would be awesome.. with i had a few grand for the c5 but don't just got laid off yesterday. ima broke kid.
Old Apr 7, 2007 | 05:25 PM
MatrixGSR's Avatar
No need to spend that much, just do a poor mans Type-R. Works and feels the same.
basketballus
Honda Civic (2001 - 2005)
May 28, 2009 12:13 PM
kobeballer96
Mar 31, 2009 10:15 AM
gloryman_17
Aug 12, 2008 02:59 AM
Hella_Fresh
10
Apr 6, 2007 07:37 PM
tha Big EZ
Jul 17, 2003 08:40 PM
