Gears
Old Aug 13, 2007 | 03:29 PM
bomber19's Avatar
Default Gears
Hey guys my gear feel like **** they are sorta stiff but they are not too bad whats the best thing to do??? Tanny oil?? problem there is that i cant find the tranny oil bung?
Old Aug 13, 2007 | 03:50 PM
posHonda's Avatar
you can fill in new tranny oil through the VSS. it would need 2.3qts i believe. get some honda MTF
Old Aug 13, 2007 | 03:51 PM
thewrai6th's Avatar
Default Re: Gears (bomber19)
Make sure your clutch master and slave cylinders are working properly and not leaking. Then, flush the transmission fluid. If it still shifts like ****, you probably have a bad clutch or transmission. I'm not helping you find the drain plug
Old Aug 13, 2007 | 05:14 PM
bomber19's Avatar
Default Re: Gears (thewrai6th)
Its Not my clutch thats fine its mainy when its cold
CnBda9init
Dec 1, 2008 10:09 AM
D-rush08
Jul 25, 2006 01:55 AM
MachAF
Aug 15, 2002 09:05 AM
TurBoXBirD16
Jun 30, 2002 11:32 AM
phear
Mar 21, 2002 05:45 PM
