misfiring out of nowhere..
recently i replaced my cap rotor ignitor plugs and wires. it was running flawless for the first couple days then outa nowhere my car started misfiring at higher rpms.. the plugs are on tight. what could be the problem?
Re: misfiring out of nowhere.. (emooheo)
you check the dizzy make sure its on tight enough? i know its a simple answer but sometimes its always the simple stuff that seems really bad
Re: (emooheo)
well i mean i could be something like that cuz you know your engine vibrates so the bolts could have come loose somehow i mean its just something to check ya know or maybe the dizzy just isnt in the right spot you may have it too far advanced or retarded but its just something to check ya know gotta rule out everything small before you start thinking big
car is still misfiring/bogging really bad. when hitting vtec it doesnt seem to pull at all. are ngk iridiums pregapped? the plugs are at about .038 instead of the stock ~.050.. my friend put them (different set) in his teg and they worked fine without gapping them.
i checked the oil dipstick and it is at a little over the first dot.
i disassembled my dizzy.. cap n rotor are on tight and wires are on goo
Re: (emooheo)
lol see bro told ya it was just an easy fix and it was a screw not on the dizzy but part of it at least yours is fixed my car still isnt firirng on the fourth cylinder im doing a compression test later today but congrats man
atlprelude01
06-23-2003 02:26 PM
