Need help
Old Aug 15, 2007 | 10:18 PM
ddenson's Avatar
Default Need help
Hi guys. I just put a B18C block in my 99 integra gsr. The block that I purchased had raised compression pistons in it and I used my old gsr cylinder head with it. When it runs though, the motor sounds like a diesel motor it knocks so loud. I already checked valve lash and set ignition timing to the same specs as the old motor and my compression is at 195 psi. I put 94 octane in it and octane booster. Anybody have any suggestions?
Old Aug 15, 2007 | 10:46 PM
l2Y4N's Avatar
Default Re: Need help (ddenson)
i suggest you find out exactly what pistons are in your block before you blow your engine.
Old Aug 16, 2007 | 08:33 AM
ddenson's Avatar
They look like j-spec type r pistons
Old Aug 16, 2007 | 08:59 AM
dizzzane's Avatar
Default Re: (ddenson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddenson &raquo;</TD></TR><TR><TD CLASS="quote">They look like j-spec type r pistons</TD></TR></TABLE>
What makes you say this?
Old Aug 16, 2007 | 09:02 AM
ddenson's Avatar
Just by comparison with pictures of type r pistons
Old Aug 16, 2007 | 09:12 AM
Rikter's Avatar
Look like and are are two different things.
I know someone that looks like jessica alba but she isin't.
-Rik
Old Aug 16, 2007 | 10:08 AM
dizzzane's Avatar
Default Re: (Rikter)
If you saw them, did you see them stamped P72 or P73 anywhere?
2kdrift
Aug 18, 2015 06:51 PM
scspeed
Sep 16, 2008 06:26 PM
alex6883
Jul 24, 2006 09:21 PM
SpeedFreak77
Apr 17, 2006 07:48 AM
fstassgsr
Aug 31, 2004 01:37 PM
