engine starting problems!
Old Aug 15, 2007 | 04:08 PM
jorge59la's Avatar
Default engine starting problems!
im having a weird problem, sometimes when i try starting my car it doesn't fire up. I turn the key to start it and i have to push the clutch in and then release and in again for a few times and all i hear is a click when i push in the cluth but it doesn't start. Then i can hear something in the bay wanting to crank but it doesn't until i play with it quite a few times then it cranks and it fires up.
Is it the starter?
its not loss of battery juice because everything else works fine such as lights, radio, etc.
thanks...
Old Aug 15, 2007 | 05:26 PM
MadVtak's Avatar
* B A N N E D *
From: Biggest Baddest Little City in The World RENO, NV
It probably is your starter, had the same problem and replaced my starter, haven't had any problems. Try checking your spark plug wires
Old Aug 15, 2007 | 05:31 PM
posHonda's Avatar
take a hammer to that starter and try starting it again. thatll answer your question to see if its the starter or not
Old Aug 15, 2007 | 07:32 PM
DAtegLs's Avatar
Default Re: engine starting problems! (jorge59la)
yo...i just had the same problem. It as my Main relay...it didnt like starting on hot days or right after i cut it off and start it again...i replaced the main relay and havent had a problem since.
mikej94civex
Apr 28, 2010 07:49 PM
pooorman's type-r
Oct 7, 2008 03:07 PM
85civic
Sep 12, 2004 03:24 PM
civicbro
Feb 19, 2004 02:47 AM
