obd2a to obd1 conversion harness
Old Aug 16, 2007 | 07:35 AM
99JdmDc2's Avatar
Default obd2a to obd1 conversion harness problem
On my conversion harness, one of the pinouts came out, does it just plug back in?
Old Aug 16, 2007 | 07:43 AM
JasonST's Avatar
Default Re: obd2a to obd1 conversion harness problem (99JdmDc2)
It depends, some use solder, and u might have to resolder the connections. Or if it's fancy it should use pinouts like the original ecu harness. Just look at is and it should be pretty easy to tell how it goes back in. If it's too hard to fix u can usually send it back to the seller and they'll fix it.
big_dong861
Nov 6, 2007 04:27 AM
CRX30436
Feb 1, 2007 09:37 AM
jisu009
Mar 26, 2004 01:13 PM
quaker
Feb 20, 2004 12:24 PM
