swapping b20b into da
Old Aug 16, 2007 | 04:30 PM
youknowimwhite's Avatar
Default swapping b20b into da
im planning on swapping a b20b into a 90 integra, i am curious as to what ecu, jumper harness or wiring im going to need to do to either convert to obd2 or obd0... do i need to convert the enging to obd0 or change everything else to obd2? any help or advice is appreciated
Old Aug 16, 2007 | 04:50 PM
deftonerider's Avatar
you can use the obd 0 ecu and distributor on the b20b
and you have to use the stokc intake manifold because the crv won't clear the hood
i've had the same swap in my car and my buddy still has it in his
it looks exactly like his stock ste up except with a different valve cover
Old Aug 16, 2007 | 05:09 PM
adamrich33's Avatar
Default Re: (deftonerider)
um doesnt the obd2 distribrutors count the cam revs at a higher number and the obd0 counts a lower number and the engine will not run, cause i got a b18b in my da and had to reuse my da dist, due to that
Old Aug 16, 2007 | 05:19 PM
PACT man's Avatar
Default Re: (adamrich33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deftonerider &raquo;</TD></TR><TR><TD CLASS="quote">you can use the obd 0 ecu and distributor on the b20b
I think that's what he meant, that you are supposed to use the stock LS distributor and put it on the B20 head.
Old Aug 17, 2007 | 04:58 AM
ok cool... so most of the wiring will just hook up if i use the b18a intake mani and distributer... that makes it sound much easier
Old Aug 20, 2007 | 02:51 PM
adamrich33's Avatar
Default Re: (youknowimwhite)
yeah that would be the best way and the quickest
grlracer97
11
Apr 23, 2005 08:20 PM
jaydm ferio
Oct 20, 2004 04:14 PM
98JDM_Type_R
Aug 19, 2004 01:51 PM
SimbaDogg
Jan 22, 2004 02:47 PM
wannakno
Jul 21, 2003 09:19 AM
