low idle
Old Aug 15, 2007 | 03:39 PM
driftahboi's Avatar
Default low idle
i noticed my car idle's at a low rpm. my friends have said it and my dad said it idles pretty low too. what do they mean low idle? at what rpm is it suppose to be at anyway. i've notcied it too cuz the steering wheel shakes. just want to know is that how its suppose to be or is there something i can do about it?
-kev
Old Aug 15, 2007 | 03:42 PM
wegotmorrison's Avatar
Default Re: low idle (driftahboi)
I think it supposed to idle around 750??
Old Aug 15, 2007 | 08:14 PM
DAtegLs's Avatar
Default Re: low idle (wegotmorrison)
its suppose to idle at 500-750rpm...it could be the main relay or the fuel pump...prolly the main relay. does it start when its really hot outside?
Old Aug 15, 2007 | 08:18 PM
posHonda's Avatar
500rpm idle is quite low. 700-800 is where it should be at.
you didnt mention at what rpm youre idling at. my steering wheel also shakes but its a result of me getting new mounts.
Old Aug 16, 2007 | 05:30 PM
driftahboi's Avatar
um yeah it starts when its realhot outside. i need to recheck back here of where it idles.
Old Aug 17, 2007 | 01:38 PM
94 IntegraLS's Avatar
Default Re: (driftahboi)
mine idles at 400... I just dont wanna clean my IAC valve because i had a bad experience cleaning one from a Ford Probe where I lost the spring and the car ran like **** even after the new owner bought a new IAC valve... im probably gonna clean out my TB and adjust the idle if cleaning the TB doesnt work.
Old Aug 17, 2007 | 02:35 PM
650teg's Avatar
I had a little idle fluctuation (not really noticeable), but cleaned my IACV and TB after a friend did the same with his 92 GSR. Now both idle very steady, and it toned down his steering wheel shake. We're both at about 700-800rpm.
If you haven't done this, you should know that it will idle funky for a little bit, until the cleaner gets completely evaporated/burned throughout the engine.
Old Aug 17, 2007 | 03:20 PM
zsudz922's Avatar
Default Re: low idle (650teg)
well one thing i would do first is run some good fuel system cleaner the next time you fill up the tank and/or you can clean the IACV and TB manually.
i had a bad idle fluctuation when i was stopped somewhere. i put in some good fuel system cleaner in with a full tank of gas.about 3 weeks later everything was all good.no more problems.
Old Aug 17, 2007 | 07:11 PM
posHonda's Avatar
Default Re: (94 IntegraLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94 IntegraLS &raquo;</TD></TR><TR><TD CLASS="quote">mine idles at 400... I just dont wanna clean my IAC valve because i had a bad experience cleaning one from a Ford Probe where I lost the spring and the car ran like **** even after the new owner bought a new IAC valve... im probably gonna clean out my TB and adjust the idle if cleaning the TB doesnt work.</TD></TR></TABLE>
wow thats a very low idle. im surprised you can tell your car is still on lol
Old Aug 18, 2007 | 02:11 PM
Default Re: (iVteC_PoWeR)
yea it idles pretty low... im thinkin about cleaning my IACV since I read that DIY about it and it looks like it has no spring... as long as I dont lose the 2 seals I should be fine... im gonna clean my TB as well to see if that helps.
Old Aug 18, 2007 | 06:22 PM
GSR15's Avatar
hey my gsr idles about 500 rpm i was wondering if the intake manifold is required to be taken off to clean the IAVC
Old Aug 18, 2007 | 08:55 PM
driftahboi's Avatar
it idles somewhat above the 500rpm range or so it seems. ill research into that TB and IACV.. and when i have the time check into those.. thanks for the advice!
Old Aug 18, 2007 | 09:59 PM
Default Re: (GSR15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR15 &raquo;</TD></TR><TR><TD CLASS="quote">hey my gsr idles about 500 rpm i was wondering if the intake manifold is required to be taken off to clean the IAVC</TD></TR></TABLE>
no you dont have to take off the intake manifold... the IACV should be bolted right to it with like 3 bolts... there should also be acouple hoses there and 1 clip.
Old Aug 18, 2007 | 11:11 PM
joaodossantos's Avatar
ye mine idles at 300-400 somtimes. and i hear a ticking/ grindin type nois from below the intake manifold. i wonder wat it is?
Ash983
Honda Civic (2001 - 2005)
34
Oct 4, 2024 11:12 AM
92_JDM
Engine Management and Tuning
Aug 12, 2010 03:23 PM
Teamdiesel
Apr 1, 2007 05:46 PM
mitch529
Feb 21, 2003 11:38 AM
