speed sensor
Old Aug 15, 2007 | 12:41 PM
95blackEG's Avatar
Default speed sensor
well my speedometer dosent work. wut could be the problem.some thing to do with the speed sensor?? not sure. lemme know .thanks
Old Aug 15, 2007 | 01:00 PM
thewrai6th's Avatar
Default Re: speed sensor (95blackEG)
http://www.hondahookup.com
Get your manual and follow the troubleshooting for VSS.
The VSS works on pulses from the rotating final drive/differential. The speedo/ECU counts the pulses and calculates the speed. Either the wire is bad, possibly right behind the intake mani it's shorted, or the speedo is dead. You test by checking for pulses of 12V at the speedo. With the ignition on and and one wheel in the air, you should see on-off-on-off pulses when you rotate the tire. If not, start checking your wiring. It's not that hard to wire up completely from scratch.
blaze.1
Sep 10, 2009 06:24 AM
LaEzEnT
Dec 15, 2008 07:50 PM
rnbguy
Oct 25, 2008 10:36 AM
rschoener
May 16, 2002 07:32 AM
