Headlight Problem
Old Nov 25, 2007 | 02:09 PM
Schister66's Avatar
Man U FTW
Default Headlight Problem
This seems to be a recurring problem with my 99 GSR. I keep burning out headlights in the driver's side.
It all started this summer. I had a set of McCollouch HID's (6000k) and had run them for over a year without problems. One day in the middle of the summer, the HID on the driver's side burnt out. I had planned to get a new ballast for the HIDs, but since i'm in school right now, its not a priority.
I replaced the HID's with a set of Sylvania SuperStars that i had sitting around. At first, the Sylvania would hardly light up. We attributed that, and the failure of the HID to a bad ground. We then grounded the headlights directly to the frame. They worked just fine after that. About a month later, the driver's side burnt out.
I figured the lights were old...they had been sitting in my garage for over 2 years. I took another set of lights i had sitting around and popped them in place. This time they were Nokya Yellow bulbs. They worked just fine until today. I got about 2 months out of them. Again they were old, but when a light burns out, its ALWAYS the driver's side. I want to get whatever problem fixed before i replace them with another set of HIDs and burn out another $100+ ballast.
Any advice? I'm not a good electrician so dumb down your answers...
Old Nov 25, 2007 | 02:15 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Headlight Problem (Schister66)
look at the sockets and see if they are nuked. i know honda has replacement pigtails.
Old Nov 25, 2007 | 02:16 PM
Schister66's Avatar
Man U FTW
Default Re: Headlight Problem (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">look at the sockets and see if they are nuked. i know honda has replacement pigtails. </TD></TR></TABLE>
do you think they short within the sockets themselves?? I can take them out and take a look....
Old Nov 25, 2007 | 02:20 PM
Dogginator's Avatar
Daisy... Daisy...
Silverstars are inherently short lived. Does the housing have any water leaks?
Old Nov 25, 2007 | 02:22 PM
Schister66's Avatar
Man U FTW
Default Re: Headlight Problem (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Silverstars are inherently short lived. Does the housing have any water leaks?</TD></TR></TABLE>
I dont believe so...as for the Silverstars, they may have already seen their "brighter" days. I had them in for a long time before the HIDs. Their burning out may have been somewhat of a fluke occurence. The thing that troubles me is i dont want to buy another set of HIDs and burn them out...they aren't cheap
Old Nov 25, 2007 | 10:11 PM
Schister66's Avatar
Man U FTW
I know its a bit of a last resort, but what do you guys think about this:
Taking a relay and wiring it onto the stock wiring harness. Then running new power and ground to each of the headlights using the single relay to tell them when to turn on and off. I was looking at a set of Hella foglights that i have and that's the method they use for turning them on and off.
Thoughts??
Old Nov 25, 2007 | 10:34 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (Schister66)
That would work and is really good solution. Aftermarket hids put a burden at start up on the stock wires. BUt it should not be that bad. I do it this way on aftermarket bulbs for customers that want brighter lights.
Old Nov 26, 2007 | 05:40 AM
Schister66's Avatar
Man U FTW
Yay! My idea works!! I AM NOT good w/ electricity/electronics so i was skeptical whether or not my idea would work. I think i'm going to get 2 new headlight pigtails from Honda and run new wires.
Thoughts on 1 wire for both sets with inline fuses or should i run seperate wires for each side?? I'll run inline fuses regardless, but what method would be better??
Old Nov 27, 2007 | 12:33 PM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">Thoughts on 1 wire for both sets with inline fuses or should i run seperate wires for each side?? I'll run inline fuses regardless, but what method would be better??</TD></TR></TABLE>
Old Nov 27, 2007 | 12:40 PM
Padawan's Avatar
Darth ModerVader
What do you mean by 1 wire for both sides?
You can get away with a single relay drawing power directly from the battery, but I'd run twin positive leads from the relay (one to each bulb), and ground the bulbs individually at the chassis.
Old Nov 27, 2007 | 12:57 PM
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">What do you mean by 1 wire for both sides?
You can get away with a single relay drawing power directly from the battery, but I'd run twin positive leads from the relay (one to each bulb), and ground the bulbs individually at the chassis. </TD></TR></TABLE>
If you need a write up just let me know. Its real easy.
Old Nov 27, 2007 | 01:39 PM
Schister66's Avatar
Man U FTW
Default Re: (wrx-killer-Sti-eater)
This is my idea so far...you're welcome to correct it if it is wrong.
Old Nov 27, 2007 | 01:43 PM
Padawan's Avatar
Darth ModerVader
Looks good. You won't need the negative wire from the stock wiring though.
BTW, did you make that drawing just now? If so, I'm impressed.
Old Nov 27, 2007 | 01:44 PM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Looks good. You won't need the negative wire from the stock wiring though.
I was told i needed that and i had to ground the relay. Are either of those necessary?
Old Nov 27, 2007 | 01:53 PM
Padawan's Avatar
Darth ModerVader
Yes, the relay definitely needs to be grounded.
The four wires that you need to connect to the relay are:
- 12V battery voltage
- chassis ground/earth
- trigger (in this case, the stock positive headlight wire)
- output to the bulbs
Old Nov 27, 2007 | 02:17 PM
Do you have a relay?
Look at the pins on the relay
And here you go.
Pin 85 from relay goes to the 12volt output from the stock headlight wire. This will be the relay trigger.
Pin 86 from the relay will go straight to ground.
Pin 30 from the relay will go to the battery. Make sure you put a fuse on it next to the battery of the proper amp rating. 25amp will be fine.
Pin 87 from the relay will be split and go to both headlights.
The ground wire from the headlights will go straight to the chassie
Old Nov 27, 2007 | 02:28 PM
Dc2FaN's Avatar
do what i did, i just got new sockets from the autozone up north and re-wired them to my stock wires...
ottobell22
Aug 8, 2005 05:14 PM
turbo'd
Apr 26, 2005 10:22 AM
geminis2k
Feb 16, 2003 08:43 AM
