maintenance required light question
Old Nov 26, 2007 | 11:58 AM
g3Gsr443's Avatar
Default maintenance required light question
so awhile back my ac belt snapped and i never got around to replacing it, and every
time i start my car the maintenance required light flashes several times then goes away.
so last night i put my winter tires on my car, and this morning it was a constant, no
flashing and remains on (only reason i mention the changing of the tires is it was the last thing i did to the car before the light remained constant). the car is not acting differently or sounding differently. no other belts or anything noticeable like that have failed. the reason for the light remaining constant puzzles me. any insight would be appretiated.
thankyou.
Old Nov 26, 2007 | 12:02 PM
AWD Terror's Avatar
Default Re: maintenance required light question (g3Gsr443)
I think the light is suppose to come on every 7,500 miles to remind you to change your oil.
Just hit the reset button
Old Nov 26, 2007 | 12:05 PM
g3Gsr443's Avatar
Default Re: maintenance required light question (AWD Terror)
just changed the oil like a few weeks ago, which reset button?
Old Nov 26, 2007 | 12:07 PM
Rainmaker's Avatar
The answer to your question in in the FAQ.
Old Nov 26, 2007 | 12:08 PM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g3Gsr443 &raquo;</TD></TR><TR><TD CLASS="quote">just changed the oil like a few weeks ago, which reset button? </TD></TR></TABLE>
Your computer doesn't know when you change your oil....
https://honda-tech.com/zerothread?id=2143378
Old Nov 26, 2007 | 12:16 PM
integraRS-T's Avatar
its going to come on every 7.500miles the reset button its under the dash pretty much above ur right knee ,just hold it down till it flashes than ill go away
Old Nov 26, 2007 | 12:19 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: (AWD Terror)
but it's not just for your oil
it's for honda's suggested scheduled maintenance thing....when it was implemented the intention was to have the dealer ONLY be the one to turn it off after service was complete (pretty dumb on Honda to think the vehicle owners wouldn't turn it off themselves)
Old Nov 26, 2007 | 12:26 PM
i wish ill take my car to the dealer every time the light comes on that would be expensive as hell how dumb of honda
Old Nov 26, 2007 | 02:07 PM
g3Gsr443's Avatar
Default Re: (integraRS-T)
thanks for the feed back
Old Dec 2, 2007 | 07:22 PM
g3Gsr443's Avatar
Default Re: maintenance required light question (Rainmaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rainmaker &raquo;</TD></TR><TR><TD CLASS="quote">The answer to your question in in the FAQ.</TD></TR></TABLE>
i found cel and abs codes in the faq but nothing about maintenance required lights...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraRS-T &raquo;</TD></TR><TR><TD CLASS="quote">its going to come on every 7.500miles the reset button its under the dash pretty much above ur right knee ,just hold it down till it flashes than ill go away</TD></TR></TABLE>
do i have to remove any parts of the dash? I've looked for this button and cant seem to find it if someone has a picture or diagram of where this button is supposed to be id appreciate it if they would enlighten me on its whereabouts.
Old Dec 2, 2007 | 07:27 PM
SuckMyDOHC's Avatar
stick your head under the driver side dash. Attached onto the plastic dash cover, you'll see a black box with a blue button. Hold it down for a few seconds and you're done.
Old Dec 2, 2007 | 07:29 PM
SuckMyDOHC's Avatar
oh and by the way....
» Search Results
Your search for maintenance required returned 39 results.
Old Dec 2, 2007 | 07:33 PM
DOHCter VTEC's Avatar
Default Re: maintenance required light question (SuckMyDOHC)
https://honda-tech.com/zerothread?id=2162114
There's a picture on that page that tells you where it is.
A picture holds a thousand words.
By teh way, how do you post pictures O.o
Old Dec 4, 2007 | 08:18 AM
g3Gsr443's Avatar
Default Re: maintenance required light question (DOHCter VTEC)
thanks!
to post pictures you have to have an account at a image sharing website (photobucket) is what i use. and you upload you photos onto that account. and it will the give you an image code or adress just copy and paste that into your post and the picture should appear<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCter VTEC &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=2162114
VtecAdvantage
Feb 22, 2006 02:31 PM
GSRerrr
Jun 14, 2005 05:37 PM
StrtMeUp01
Jan 16, 2005 06:50 PM
papa5murf
Honda S2000
11
Sep 9, 2004 12:21 AM
sExy_TinKY
Jul 3, 2004 11:06 PM
