check engine light
Old Nov 29, 2007 | 06:37 PM
envision's Avatar
Default check engine light
is there anyway i can make the CEL go away in my 94 GSR? The thing is im using a obd2 ecu w/ a jumper from obd2 to obd1. When i used to have a ITR ecu obd2 there was no check light but now i have one for this ecu. Anything i can do?
Old Nov 29, 2007 | 07:03 PM
St Jimmy's Avatar
* B A N N E D *
Default Re: check engine light (envision)
Yes, you pull the code and figure out why its turning on. You fix the problem and it will turn off. Thats usually how most CEL's work.
Old Nov 29, 2007 | 07:10 PM
envision's Avatar
Default Re: check engine light (St Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">Yes, you pull the code and figure out why its turning on. You fix the problem and it will turn off. Thats usually how most CEL's work.</TD></TR></TABLE>
how would i pull the code? and how would i fix the problem? would i need to take it to a shop for that?
Old Nov 30, 2007 | 12:03 AM
clean3two3's Avatar
https://honda-tech.com/zerothread?id=978933
read and it will explain to u
Old Nov 30, 2007 | 04:18 AM
Dogginator's Avatar
Daisy... Daisy...
Do you have the secondary O2 sensor and other ODBII sensors on your 94?
Was the ITR ECU JDM?
ajbreezay
Nov 8, 2007 04:53 PM
Team Protocol
Jul 12, 2007 05:57 PM
gsrhatch1126
Jul 5, 2005 06:45 PM
Xumarius
Jul 19, 2003 09:22 AM
