trouble getting into 1st
Old Nov 26, 2007 | 11:34 AM
HONDRETTI's Avatar
Default trouble getting into 1st
from a dead stop i have trouble getting into 1st...its not really a grind, its just tough, almost as if i have to force it... if i were rolling into gear it goes easy...
i dont want to assume a bad tranny...bushings?
Old Nov 26, 2007 | 12:07 PM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
Default Re: trouble getting into 1st (HONDRETTI)
I think that's fairly normal. When I have trouble going into first, I'll try shifting into 2nd or 3rd - then going into 1st, and it usually goes right in.
Old Nov 26, 2007 | 12:46 PM
Integ-boy's Avatar
Default Re: trouble getting into 1st (Tim2179)
From what my brother told me that is cause by a worn out throw-out barring. my gsr has the same problem but i just dbl clutch when putting it in 1st
Old Nov 26, 2007 | 01:53 PM
teggy_94LS's Avatar
Mine does the same exact thing, I just deal with it.
Old Nov 26, 2007 | 03:10 PM
CeReal's Avatar
Default Re: (teggy_94LS)
has anyone mentioned letting the car roll back for a second yet?
Old Nov 26, 2007 | 03:25 PM
Spugen69's Avatar
if you put the clutch pedal to the floor usually helps.
Old Nov 26, 2007 | 04:50 PM
bjones's Avatar
Default Re: (Spugen69)
you might have some air in your lines, try bleeding the clutch
Old Nov 26, 2007 | 07:43 PM
beast18gsr's Avatar
When that happened on my car the resivoir was low check the fluid
levifps
Mar 27, 2007 12:23 PM
lude98SH
Oct 25, 2005 09:10 AM
Toretto
May 12, 2003 01:02 PM
gleinz
Nov 17, 2002 04:06 PM
hybrider
Aug 3, 2002 06:20 PM
