tranny problem???
Old Nov 29, 2007 | 03:13 AM
polishedturd's Avatar
I like PIE
Default tranny problem???
so my tranny goes into gear fine when i shift below 3k but after that it gets to where i have to almost force it into gear! please help h-t, what can it be, do i need a new clutch, bad syncros, im due to change the fluid this weekend will that help any? thanks h-t
Old Nov 29, 2007 | 04:31 AM
AWD Terror's Avatar
Default Re: tranny problem??? (polishedturd)
What tranny do you have?
Does it grind when you force it?
Do you have any short shifter in?
Last tranny oil change?
Old Nov 29, 2007 | 05:27 AM
HONDRETTI's Avatar
Default Re: tranny problem??? (AWD Terror)
im having the same problem, except its from dead stop
its not the fluid, mine is fresh.... my bet is the synchros
Old Nov 29, 2007 | 05:55 AM
I like PIE
gsr tranny
it doesnt grind its just hard to go into gear when driving and shifting above 3-3500rpm. when i am stopped and switching from gear to gear its as smooth as butter.
stock gsr shifter
im unaware when the last tranny fluid change was cause i just got the car a few months ago(i know i should have changed it as soon as i got it)
but i did some searching and i think it might be a/some broken springs on the clutch disk.
Old Nov 29, 2007 | 05:59 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by polishedturd &raquo;</TD></TR><TR><TD CLASS="quote">
but i did some searching and i think it might be a/some broken springs on the clutch disk.</TD></TR></TABLE>
I have seen this happen a few times. How many miles are on the clutch?
I would change the fluid first though, you may get lucky.
bomber19
Oct 3, 2007 05:57 PM
rac3rb0i
Nov 30, 2004 11:02 AM
HXvtec
Oct 14, 2004 11:27 AM
ChingonGSR
Apr 18, 2003 11:16 AM
bones_accord
Feb 16, 2003 08:12 PM
