how do i wire this
Old Nov 28, 2007 | 09:52 AM
HONDRETTI's Avatar
Default how do i wire this
did a b16a swap, now i need a second O2 sensor...it goes AFTER the cat, right?
now i need to fabricate a bung and screw the sensor in...i have TWO wires hanging down (pictured) and a ONE wire O2 sensor...do i just cut the terminal and splice all three together?
Old Nov 28, 2007 | 09:58 AM
95 integra's Avatar
Default Re: how do i wire this (HONDRETTI)
Get a 2 wire O2 vs the 1 wire.
Old Nov 28, 2007 | 11:02 AM
SuckMyDOHC's Avatar
What year integra? Anyways, the 2nd O2 sensor goes into the cat
Old Nov 28, 2007 | 02:04 PM
HONDRETTI's Avatar
Default Re: (SuckMyDOHC)
90 integra with a 91 SiR swap....
i figured it out now, i think one of the wires is extra so i can go onene wire, and i know the first O2 detects air/fuel, and the second O2 detects cat. emmissions...
so i would drill a hole AFTER the cat. (not into the cat.)
Old Nov 28, 2007 | 02:06 PM
Jtuned DC2's Avatar
* B A N N E D *
It supposed to be at the end of the header but i geuss after the cat works
Old Nov 28, 2007 | 03:54 PM
SoTexDC2's Avatar
Default Re: (Jtuned DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jtuned DC2 &raquo;</TD></TR><TR><TD CLASS="quote">It supposed to be at the end of the header but i geuss after the cat works</TD></TR></TABLE>
Depends on the year, my 01 GSR has an Oxygen sensor directly in front of the cat, and one directly behind the cat.
OP: If your not running an OBDII ECU, you only need one Oxygen sensor, pre-cat.
j.orr
Mar 25, 2009 09:25 PM
HONDRETTI
Nov 28, 2007 11:03 AM
zoniebutt
Nov 14, 2007 03:30 PM
bbhockey19
Oct 31, 2006 04:03 PM
Civicse
Dec 20, 2005 07:23 PM
