DA Issues
Old Nov 29, 2007 | 06:21 PM
ProSlow07's Avatar
Default DA Issues
There isn't very many diagnosis links in the FAQ so I figured I would write it up.
Acura Integra LS
148k
Auto-madness!
DD
First, the interior light, corner lights don't like to come on everytime and the dash clock seems to reset during periods of not running. Any one know why?
Also, my car starts to over heat after it warms up while idling but when I am just driving around it seems to go down to normal temp. Any ideas?
I put skunk2 suspension on my car and now the back kind of squeeks while going over even the smallest dips or bumps. Any clue why?
Last but not least, I have a vibration problem. The car seems to idle rough and tends to vibrate the steering column plate, the steering wheel, and other interior pieces. Any help on this one?
Anyway, thanks for the help everyone. I'll try and get pics up of the car soon.
Old Nov 29, 2007 | 07:58 PM
jhammond_82's Avatar
Reject Papi
Default Re: DA Issues (ProSlow07)
ok, 1st, the lights, and clock. is there a loose wire somewhere? maybe moving around connecting, not connecting ect.....2nd. if you put lowering suspension on your car, the squeaking may be from the struts, are they stock? did you replace any of the stock bushings? 3rd. the vibration, is there a vacuum line off, or with a hole or torn? loose exhaust parts, ect....ohhh, and 4th. overheating, is the fan kicking on and off like it should, since its cold now, the cold air might be enough when moving, to cool the motor down, check the thermostat, maybe its stuck, or old and needs to be replaced, check the sensor, and stuff like that.
Danigirll
Nov 18, 2017 07:14 PM
nthao89
11
Dec 9, 2008 06:50 AM
mrbig
Mar 11, 2005 03:48 PM
c8r9x
Apr 23, 2004 08:10 PM
