Help interpreting codes
Old Nov 25, 2007 | 05:45 PM
Audiojb's Avatar
Default Help interpreting codes
I just did a CEL check and my 95 gsr was throwing 3 codes
6 ECT - water temperature sensor
22 VTEC pressure valve
41 Primary oxygen sensor heater(focusing on this one first)
If someone could lead me in the right direction please do so. should I replace the o2 sensor or what?
Old Nov 25, 2007 | 06:55 PM
St Jimmy's Avatar
* B A N N E D *
Default Re: Help interpreting codes (Audiojb)
Check the ECT to make sure its connected and not broke.
Is vtec crossing over? If so then who cares about 22
Check o2 sensor wiring and you can also check the resistance in the signal wire to see if its working properly.
Old Nov 26, 2007 | 07:49 PM
beast18gsr's Avatar
most the time with an o2 code on a obd1 car u have to replace the sensor itself
Old Nov 26, 2007 | 08:05 PM
nsxtasy's Avatar
H-T Order of Merit
Look in your service manual. It tells you the diagnostic procedure and what to do for each of the codes. You'll find it at the start of the Fuel and Emissions section.
If you don't have a service manual, get one! You need it if you plan to work on your own car. You can buy one here.
S2KILLA
Jul 7, 2010 08:30 AM
junior_tm
May 7, 2009 09:46 PM
93CamaroLT1
Oct 20, 2008 04:35 PM
omil2374
Oct 17, 2006 12:30 PM
Vinhtran17
Jan 20, 2004 04:26 AM
