spring rate
Old Dec 6, 2007 | 10:26 PM
JDM.DEEBO's Avatar
Default spring rate
im going to get some funtion forms...and i just wanted to know what spring rate would you guys recommend me getting. thanks
Old Dec 6, 2007 | 11:43 PM
VRD^sam's Avatar
Default Re: spring rate (JDM.DEEBO)
what is your car going to be used for? DD,autox,drag????
Old Dec 7, 2007 | 04:29 AM
PrinceAli132's Avatar
Default Re: spring rate (VRD^sam)
We have to know what your doing with your car in order to give you a better response.
Ali
Old Dec 7, 2007 | 04:40 AM
AWD Terror's Avatar
Default Re: spring rate (PrinceAli132)
Check out some info in the suspension forum
Old Dec 9, 2007 | 06:24 PM
JDM.DEEBO's Avatar
its for autox...and dd......both....
Modified by JDM.DEEBO at 11:00 PM 12/10/2007
Old Dec 10, 2007 | 10:00 PM
JDM.DEEBO's Avatar
ttt
Old Dec 10, 2007 | 10:31 PM
JDM.DEEBO's Avatar
anyone
Old Dec 11, 2007 | 01:33 AM
alexisthemovie's Avatar
ots
Old Dec 11, 2007 | 04:07 AM
Something along the lines of 10k front and 8 k rear should be good. Im not sure what spring rates they have but something in that ballpark should be plenty good for daily use with occasional track.
If your looking for a rear biased setup that maybe 8k front and 10k rear or 10k front with12k rears.
Ali
Old Dec 11, 2007 | 11:50 AM
JDM.DEEBO's Avatar
why 8k f and 10k r????? why is it higher in the back. i thougt that it should be higher in the front.....
Old Dec 11, 2007 | 12:27 PM
Its been discussed quite a bit in the roadracing/auto-x section.
It seems as though many who track their cars here (US) prefer a stiffer rear spring to help the car rotate better. However, a lot of JDM setups use a stiffer front spring.
Search around in the RR/Auto-X section, you'll find some good threads.
Its going to come down to what works best for you and how you want the car to feel.
Ali
Old Dec 11, 2007 | 12:35 PM
BlueR's Avatar
while you can order up any spring rates you want, just make sure the shocks are properly valved...
we can spit out 15 defferent spring rate setups for any need you may have...
all will be moot if the shocks are generically valved
Old Dec 11, 2007 | 12:37 PM
Default Re: spring rate (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">while you can order up any spring rates you want, just make sure the shocks are properly valved...</TD></TR></TABLE>
QFT!
Ali
Old Dec 11, 2007 | 08:35 PM
JDM.DEEBO's Avatar
thanksssssssss
94turbosi
Suspension & Brakes
11
Mar 7, 2007 07:30 PM
SHG_EasyE
Suspension & Brakes
Dec 14, 2006 04:04 PM
b18crx
Nov 14, 2003 06:12 PM
austrian type-R
19
Nov 13, 2002 04:57 PM
